ORIGINALLY THOUGHT THESE WERE FEDERALS WHEN I POSTED THEM UP BEFORE BUT THEY ARE ACTUALLY FALKEN AZENIS!
hey guys,
picking up a set of wheels tonight with falken azenis semi slick rt615 slicks on them, but they are no use to me as i dont do alot of circuit racing so going to sell them off to replace them with other tyres which i need ASAP so these MUST be gone by tomorrow!
they have been driven on less than 800KMS and are over $300 EACH when new, willing to let go for half the price of that.
$600 only! i may be be slightly nego if you call me and sound keen enough
IF YOU TAKE THESE OFF MY HANDS BEFORE 5PM TODAY (21/02/2013) ILL DO THEM FOR $500 NOT NEGOTIABLE
0481 112 959 Liverpool, NSW
all 4 are 255/40/18
Edited by sirdriftsalot
    • Did a conversion on my rb20 with rb25 cam and pulley, controlled it with a solenoid (forgot the port diameter of the solenoid)  and made an oil port on the cam cap to lower pressure in the journal. Difference  is day and night, the rb20 isn't dogshit down low anymore, not a powerhouse but this had add much welcomed torque down low. Boost build a bit sooner and torque rise way more when it start building boost. Only need to deactivate the VTC past 6500/7000rpm.   Knowing how it help with only 2L, having it on 2.6L it should be a mod to think about early on as it gives a lot of performance on most on the rev range.
    • https://www.nengun.com/hks/valcon-rb26-v-cam-system   no controller but most will use ECU to control anyhow
    • Not too sure, the throttle body has 4separate plugs going to it. Im not sure if the throttle is driven by cable and the motor is for traction, cruise and something there light blue one is TPS. i don't understand why the throttle won't open with the cable until about 3/4 on them only moves the valves very slightly
    • There are other crowds doing 25Neo conversion kits.
