hey, my timing belt has become noisey, i know its the timing belt because a mechanic friend dripped some water on the belt and the noise dissappeared for a day then came back, its like a SSSS-SS-SSSSS-SSS-SSSS-SSS noise if you know what i mean.
The belt is due for a change, but appears good still with no cracks etc.
Question is , ive had the front cover off and the belt and pulleys are exposed to the air, so would this being doing somthing to the belt?
and will the new belt make this noise after a short time due to being exposed too?
timing belt has done 65000k's
Edited by AngryRBGTX
https://www.sau.com.au/forums/topic/420313-timing-belt-noise/
I would be replacing the belt and bearings etc ASAP man, your motor is relying on it and it ifs making noises that is generally a bad thing!
heavily agreed.
Otherwise having that cover off wont do anything untoward unless you drive through a big sand dune or otherwise live in a really dusty dirty area.
Beyond this the cover can often hide noises from the cam belt system so when you remove it you can then notice noises more. (this also works the other way round like with my car where the cam cover was resonating a weird sound and this stopped when the cover was removed :S [fixed now- new rubbers])
yeah, ive got the new belt so ill take it off road til its done im just wondering if this noise will come back if i keep the cover off, i kept cover off cause it seemed noisey with it on and i broke 2 CAS's and was worry it was contributing at that time. :yes:
When you took the top cover off, did you pack out the CAS to suit?
Makes a good noise while the CAS has its guts pushed out.
not sure what you mean, i replaced that outer rubber gasket and just bolted up as normal, the sound is definitely the belt, although the engine does make kind of a mitsubishi magna sound which might be the cas?
yeah thats correct then,
Basically you cant just remove that cam cover as well as the rubber gasket as you will have seen there are basically some washers in that gasket where the CAS bolts on to and this spaces it out by the desired amount. If you put the CAS straight back on without this spacing there it can do some damage to it all.
Also, from my experience, i hope you managed to get the CAS back on exactly at the same point as it was. Mine was out (rotated) by 2mm which wound up being 4 degrees retarded. And thankfully retarded and not advanced!
Edited by jjman
yeah i put those spacers on with the gasket, i learnt the hard way and broke two CAS due to incorrect spacing and alignment and i broke the gear off the cam too, bloody expensive mistakes!
does anyone know how accurate the timing marks are? ive just taken everything off and have it all lined up to the marks, the crank is spot on but the cam wheels are both slightly off, but that might be just the way it is, probably need adjustible wheels to get things perfect???
the marks are spot on.
if they are out, i would be saying youre a tooth out somewhere.
get your mechanic to check it if youre not 100%
With my crank at TDC both my cam marks were about half a tooth retarded. Dialling them in they were 3.5 degrees exhaust and 6.0 degrees inlet out. Marks lined up after pretty much spot on after
really?
mine were spot on.
not out in the slightest.
go figure....
maybe the old belt must be a bit stretched because its a little shorter and was bloody hard to get on it and now its pretty much spot on, the exhaust cam looks slightly advanced but close enough.
my noise was more of a hissing, but the noise you have is what i had when the top cover was on,
could that top cover be getting rubbed by the belt i wonder? id really like to get to the bottem of that noise
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
