These pictures might answer the first part of your question.
Nissan Japan manufactured the Skyline with this front...(as you put it without the series 3 healights/guards) the only differene is they didn't use the extra driving light like the local 31's have.
I'm looking to do a diff converion to my s3 wagon. Some skyline sedans had a h195 live rear end. Don't hear about them much though.
To save you the reply, I know the springs mount differntly on the wagons, just haven't had a good look at a h195 to see if it will be doable yet.
Um...aren't all Aussie Skyline diffs the same apart from the ratio and the fact that some are LSD? and the mounting points for wagon?
possibly the axles are a bit shorter on a wagon (havn't checked this out yet, because im wondering too)
What is the point of this conversion? Or are you trying to put a sedan rear suspension setup into a wagon?
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. 😭
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
