Ok fitting my front turbo dump pipe and xforce cat this weekend to my R33 GTS25T is there anything i need to know or do just to make life easier in the process i only have access to ramps and trolley jack.
I already have a Nismo cat back 3 inch system so im guessing a cat and front splite pipe from turbo should fit on np.
Use plenty of lube! Those bolts and nuts are going to be rusted. Might want to buy a whole new set of high tensile fasteners. If you're removing the dump pipe, you might as well change the turbo outlet gasket, if you haven't done it in a while.
Are you using the stock front pipe? This piece has a little lip where it meets the dump pipe, meaning the internal diameter tube sticks out from the flange, and it might not fit properly into your new dump pipe.
Make sure you are using the proper Steel gasket for the dump pipe, if you get given one that looks like paper between two sheets of aluminum then give it back cause it will leak, tighten the bolts a little at a time and evenly, and dont cross thread anything or you will want to cry and swear alot :domokun:
Edited by AngryRBGTX
Ok yer i was guessing rust would be prominent as far as i know the its the whole system from turbo and cat so im not using any stock exhaust components except bolts.
i was also told use Loktite on ALL exhaust bolts dont drown it just a swipe on 1 side of the bolts or nail polish if i dont have loktite.
Is there any gains in cleaning my o2 sensor if so how would i go about doing it if i can.
also i remember on my TX3 i had a turbo to manifold gasket that was like a perferated steel looking thing it burnt out same day it was installed and started leaking so i stay away from that crap.
Yer well weather wise the exhaust didnt happen wasnt interested changing it in the rain so next week will have to do thanks for the help guys yer was going to take the heatshield and that off will it be a good i dea to mod the HS abit so it fits back on with the 3 inch exhaust im sure it will help with engine bay heat ransfer or somthing. maybe looks.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
