Oh... I listened to the fax make a connecty sound. Will take a photo of my forms and email them through.
lol so the good news is; the fax hasn't actually been disconnected yet, although it should have been.
the bad news is you faxed the form wrong side up :P so I got 2 blank pages and no idea who to chase!
Chase.... ME! =-D
Nah it's all good. I photo/emailed the same forms through. Last time the same fax machine here at work decided to eat most of the form and pass the second page through without scanning it.
Faxes should have died with 56k baud modems if you ask me. ;o)
Not long now, unfortunately looks like my 32 wont be ready as funds have dried up for a little. But will be comming down once again to help out with timing, sign up and pointing and laughing at crazy driving ;) But definately will be driving in the next one :)
Yes i have it here i shall put it in my car now i also have the number "14" windscreen number that u guys had at the last texi i did, i forgot to give it back :P So thats in the car to lol.
Hi Guys,
I am from Tamworth NSW (about 5 hours away) but should be getting my car tuned in Newcastle on the 29th. Is there someone I can contact on the 29th in the evening to check if there are any spots left or should I post on here? I just want to make sure tuning is all finished and goes to plan before I commit to a day of skids/limiter!
Thanks
Best bet is to check in here and/or come on the day. We will post up in here if it is full.
Even if you don't run would be a great day to come and meet some of your Southern NSW Skyliners.
    • He made that comment in my thread - In my case the vents ARE to lower engine heat, when the car is not moving, which is the only scenario I have heat problems with the aircon on, sitting in traffic, on 40C+ days. I can't imagine a scenario that this NC needs any at this point in time. I do not know if it will actually make my cooling when the car is MOVING worse, and I sincerely hope that won't be the case. If it does, well, um, f**k.
    • Nice, thanks. Thats why I was asking, there'd been a fair bit of discussion in the E90 world about vents and where it makes sense to put one (ie, over the filters is not great as that is inline or slightly behind the struts and in higher pressure area). I struggle with air flow and pressures. It sill weirds me out that a radiator in the boot can work.
    • Neither really Vents, when located in the right place, will lower the engine bay "pressure", as air has a path to escape, thus lowering the engine bay pressure, thus.....improving the efficiency on the coolant stack (read: IC, condenser, radiator) This is why the Blits vented bonnet on my 33 worked so well, the vent was in the front 1/3 of the bonnet, which put it right after the radiator  If the vents are to far back toward the windscreen, which is a high pressure zone, it can actually force air into the engine bay, causing higher pressure and effectively loosing efficiency on the cooling stack, like the fab of raising the rear of the bonnet, which does allow heat to escape, but only when the car isn't moving  There's heaps of cool "fluid dynamics" info out there, but, I'll attach a video of a 'Merican joint that focuses on "Miatas" as I found it when looking into vents for mine, they explain it way better than me
    • Poor bleeding. That stupid damping loop in the plumbing that should be completely replaced with a braided hose. Just the first 2 that come to mind.
    • Forgive the potentially silly question but are the vents for bay temps? I've been toying with how to reduce my bay temps because man, it gets HOT in there and a small subtle vent somewhere I think might help. Or, maybe they're to assist with just the intake temps?
