Woooooo only a couple of days to go, im dusting off the SAU members shirt, geting my timing thumb ready by furiously mashing xbox buttons. Just to make sure the times are even more acurate this time lol. Guess I better give my baby a wash so she looks half decent sitting in the carpark lol. Very tempted to bring the 32 down but dont think it will pass inspection with no rear or quarter glass lol.
Sorry Andy - I've been way behind in this (as evidenced by my absence from everywhere lately).
Tonight I'm going to try and link all payments with forms and shoot off PMs to everyone.
Again - apologies that I'm behind on this.
G'day fella, thanks for letting me know. Sorry to e a pain, I was looking for a list of who has paid and when I couldnt find it I thought I'd check that my pay went through ok.
Hope your foot is healing up ok mate. Catch ya soon ?
Don't matter mate, I have the reflexes of a ninja.
They will still complain you didn't press the button quick enough ;)
I will need about a 30-45 second handicap, kthnxbai
You guys need a hand on the day
i would be very careful about offering Andy a "hand"..... babies have been known to happen that way
our handies bring all the andys to the yard
Us Andy's sure are randy with our handies.......
Hmmmmm that sounded better in my head hahahahaha
With regards to suspect times, the only suspect times will be when it's so Long on the course cos we forgot the course and made up our own one, then we still got lost, did a few skids then come back after getting lost again....... Ahhhh good times
I've got a new marker for that on the time sheet CBFRS can't be farked, ripped skids
  • Like 1
Hey folks we've only got about 10 spots left. So if you deposit it your money today you'll be guaranteed a spot. If not then show up on the day and take your chances.
Can't wait! Weather is shaping up nicely - mostly sunny & 27!
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
