[Nsw] - White Evo 7 Stolen Plates Myswag, Merrylands Area
- Carbon fibre wrap - roof and rear wing blade
- HKS Kansai front lip
- Cusco powerbrace (painted in white)
- Side skirt ext & side spat
- Cusco full roll cage (in black)
- Front number plate contains "The-Lowdown.com" sticker
- Tow hook (colour is "purple" I believe)
- Contains CEO sticker @ the rear wind screen & rear passenger.
- Black Gramlight 57D with illesst sticker
Thanks for the comment guys.. I know it's a low possibility, but we need as much help as possible..
Edited by r3232r
CBD to West daily via M4/GWH. Will be doing a return run to Buxton late tonight. Hopefully spot it on the main roads
Though I'd imagine its been stripped already due to it being so unique. Keep an eye out on parts on gumtree.
Hope it is insured, these days crooks that steal those kinds of cars don't drive them around for long.. they end up stripped and put on forums/eBay etc.
Update from another forum
URGENT PLEASE HELP
THERE WAS A SIGHTING OF BLACK 300ZX WITH MY NUMBER PLATES (MYSWAG) SEEN DRIVING AROUND PARRAMATTA
Just
spoke with the police and they said next time if anyone sees my car or
my number plates to call the police straight away and they will send
cars in the area to the area and direct it was going. even if it looks
similar please call. If it is ok the owner of the car wont get in
trouble but please do you can call 000 or 131 444
  • 3 weeks later...
    • Yeah. OK. I'll say the same thing I say to everyone. You do not have to use 100% throttle all the time.
    • Mainly being afraid of breaking something on something i've poured so much money into haha
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
