hi all,
got me an R33 GTS-T, i think is it's model. It's a turbo'd car that has been sitting unused since mid 2011. It was stolen at one point and the dash has been destroyed
can anyone please tell me, where should I go to get replacement parts for the dash? How do I tell exactly what kind of skyline i have? what kind of work should I do to get it running properly and in good shape? At the moment it's not showing any boost and seems as though the blow off valve is stuck open or something, where is this and how do I check it? It is also idling rough and stalls
I live in newcastle NSW
Thanks
Tim
https://www.sau.com.au/forums/topic/420431-got-a-r33/
try an import wreckers, ebay, the for sale section on this forum and even your local nissan dealership for parts for the dash.
as for what model it is, the import plate and build plate should tell you what model it is, as well as the vin number.
if the stock dash boost gauge isn't showing boost, then it may just be that the line to the sensor is split (common problem). easy way to tell this is by whether it shows vaccum at idle as well. if it doesn't then the line is split
https://www.sau.com.au/forums/topic/420431-got-a-r33/#findComment-6762738
hey guys thanks for the replies. I located the little hose for the dash boost gauge. It was indeed split as it has hardened. It now shows a vacuum at idle
I still don't have any boost though... any ideas what I can check? I have put soapy water around the intake and intercooler pipes with no bubbles apparent. I don't really want to have to pay someone to look at it as I want to learn this myself.
I can hear the turbo spooling up and it sounds as it should
Engine seems to have a miss too :/ It's on 135,000kms approx and doesn't seem to have had a major service, possible plugs leads issue?
Thanks guys
https://www.sau.com.au/forums/topic/420431-got-a-r33/#findComment-6781938
I'd personally change the coilpacks (they cause missfire and stutering of the car) along with the spark plugs, fuel filter, oil change, oil filter, timming belt with tensioners etc..., accessory belts, radiator flush with new coolant.
Just to be on the safe side this should have all been done as a part of the 100k service. If your timing belt snaps you will need a new engine.
Doing the major service might eliminate some if not all your issues minus the boost problem.
Edited by DarkRyda
https://www.sau.com.au/forums/topic/420431-got-a-r33/#findComment-6782023
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
