Recently my 4wd light has been coming on, either when I remote start my car, or if I coast the car in neutral for a bit shortly after starting.
Turning the car off and on fixes the light coming on, any ideas why these things trigger the light the come on? Always restarting my car as I have read having that light on can cause damage
Edited by Booki
So don't coast in neutral or remote start, seeing as there's no need to do either of those things ever.
But, for the actual problem, one would have to assume that your ATTESSA computer thinks there's a problem. You need to put it into diag mode or get a scan tool connected and see what the codes are.
By coast, not for long periods of time, maybe for like 5-10 meters.
Got a diagnostics cable and running a power fc + hc.
How do I check for errors/enter diagnostics mode
No need to go mechanic or diagnostic tool
When the 4WD light is ON
Open the boot with ignition on and look at the bottom of the 4WD computer should have an LED flashing
Count the flashes then either find a table on google of fault codes or post up here
There should be quick flashes and long flashes
Hope this helps
Had the same issue, In my car it was a dirty signal coming from the TPS that upset the 4wd computer.same guy that diagnosed the problem also fixed it. Sorry im not much help.
After stopping for lunch today, getting back into my car the 4WD Light wouldn't go out. The car was stationary (parked).
I checked the boot to look for error codes/lights but couldn't see the little box flashing. is it on the front, left, right or rear?
I had to get back to work, so i put it in RWD mode (brown connector) and just got on with my day.
Next time i got in the car, 20km's later, i put it back to 4WD mode (connected it back up) and it was all sweet..
Is it normal for the 4WD light to just come on randomly when first starting the car? Its never come on while driving since the initial start of the thread.
Of course it's not normal. There is obviously a fault. It just depends whether it is a serious fault with something mechanical, or just a minor fault with a sensor (like the pressure sensor that tends to cause problems).
If you can't see the light yourself, go to a mechanic with a decent scan tool and see what it spits out. Shouldn't cost you more than a 6 pack of beer.
In the GTS4 the attessa computer is mounted underneath the rear parcel shelf, behind the plastic cover in the boot, next to the battery and above the fuel tank.
Mine played up along time ago, randomly doing it when starting the car or coasting, sounded like similar symptoms to what you're having.
Turned out my rear wiper spritzer was leaking when I used it, that would drip down under the parcel shelf (taking some of that foamy yellowish stuff underneath the parcel shelf) and work it's way into the computer.
I noticed it when I took the attessa computer out to have a look at it and had dirty looking stuff sitting ontop of it. Opened it up and gave a good but gentle clean with contact cleaner. Put it back in and hasent been an issue since.
Is the car safe to drive with the 4WD light on?
Or should i continue to put it into RWD mode in the event the light doesn't turn off?
I will have to look into it more over the weekend, its just inconsistent, so i take it the error codes/led's don't blink when the light doesn't come on?
Thanks for all the advice thus far people!
Edited by Booki
  • 1 month later...
Bit of a thread update, I finally managed to check the error code when it came up again.
I got 7 Long flash's, 5 short. Which i believe is error code 75
Now if only I knew what that meant....from some googling its apparantly the TPS sensor for Vspec models, though mine isn't Vspec!
Has come on ONCE while taking a corner a little harder and giving it some, otherwise only during startup.
Had a look at the TPS voltage from my Apexi power fc hand controller, from memory it was around 0.3v, is this normal voltage? Perhaps thats why its throwing up the error? As because when i accelerate a little while starting and hold it for a few seconds, the error code has never come up again.
Could the reading from the Apexi Power FC be false?
If not, how can i fix it?
Is the .45v reading when the car is on, cranking or just with the ignition on and car off?
Also the reading is when i have the ignition on, not when the car is started/idling.
Edited by Booki
Ignition on or idling. No difference. Closed throttle is closed throttle and the ECU has a regulated 5v supply to these sensors.
adjust the closed TPS by physically adjusting the position of the switch relative to the shaft. Search and find the howtos (or just look at it with your eyes and see how it's done).
https://sites.google.com/site/tyndago/gt-rattesainfrormation
Attessa codes in there
i had this EXACT code come on intermittently for a while staying on for a few days till i reset the 4WD computer
I'll list what i did
In my case:
1st thing i did was readjust the TPS, also running Power fc.was fine for a week then light came on again
2nd Replaced the TPS, again lasted a week or two the light came back on
3rd Replaced the 4WD computer with a known working one, Lasted a month then came on at the track
4th Researched and found a guy in the UK who had same issue and found was a dirty ground on the alternator. So i cleaned the ground on the alternator and was good for a week or two and light came back, this is the weird part when the 4wd light came on this time the HORN stopped working!!!
5th and final!!! Found a dodgy ground on the horn, Replaced the ground and ever since, touch wood, 4wd been working perfectly for well over 2months now
i hope some of this helps!!!
Any questions feel free to PM me
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
