I take it that the fast tuner is exactly that, a tool to get a quick and decent result? for people with limited experience/know how.
It doesnt surprise me that someone who has tuned cars in more countries than i've been too doesnt use it. :P
Will do, im quite excited. Should be many hours of learning and tinkering.
I'd be interested to see how your ignition table comes out. I think tuning the AFR to your targets is far simpler than tuning the ignition table. Ive got WARI installed(I don't have the ECU, just playing with the software) and the base map for an R33 looks a little heavy on the retard side. I'm deciding either between the adaptronic select or a haltech platinum pro. It would be awesome if I could tune it my self but the things that can go wrong if the ignition table isn't setup right isn't appealing. Even on cruise, Ive read if the ignition table is too retard you increase combustion temps. I think for any home tuner its probably worth while to get a EGT sensor installed.
I read someone here done back to back installs with a EGT sensor inside the collector housing of the mani and another one post turbo and the temperature change was 40 - 50 degrees less. Its a change but if you set a good upper limit and stay about 100 degrees under that, it should be safe.
Guilt toy what are your target AFR's on standard 98 fuel? What are your tips for a novice home tuner on working with the ignition table. Would you start with the standard base tune and work around that? If you have another tune, from a PFC for example, could you use that as a reference for the ignition map?
My egt's were around 50 - 100 degrees cooler in the dump so you are about spot on. I would be running it in the manifold close to the head or at the merge.
I found having an egt gauge interesting, the tuner was definitely more confident to tune closer to the limits, and we were able to lean out the cruise while keeping an eye on the exhaust temps. It was especially reassuring having it at the track as I didn't see over 900c up the straight, even after hitting the soft limit a few times (damn auto box).
Some Japanese tuners prefer to watch the exhaust temp rather than the wideband from what I hear...
You aren't wrong with that statement. Are all the EGT's the same? My main concern about putting it in the collector is if the thing ever snapped and my turbo had to eat it. Another concern which I thought of, and read on this site I think, is that the material the dump is made of(mine is a stock dump so cast iron) and the material of the heat probe have different expansion properties and this guy said that when his car heated up, the probe was coming loose. What should be the upper limit temps to be seeing? From what Ive read 850c is generally the good limit to stay at or below.
As long as you get a good quality electronic gauge it should be accurate, and the tip should never snap off. (mine is around 5mm in diameter and looked perfect last time I removed it.) The material you tap it in to shouldn't make much difference, the thread is tapered so it will bite nice and tight into the tapped hole, as long as you use the correct tapered tap. If the Adaptronic has the ability to log 6 channels I would run a temp probe in each runner to allow individual cylinder trimming.
The max temps you want to see is dependant on timing. The less timing your engine is running the higher the exhaust temps will be compared to the combustion chamber. My engine runs very little timing under load as the boost is so high.
Imagine how soft the alloy pistons would be at that temperature, they would be so weak a little det would punch a hole straight through them. Luckily our pistons all run oil squirters underneath to keep temps under control, my stock pistons also have a donut shaped oil channel cast into them to help transfer the heat into the oil.
  • 1 month later...
Thinking about getting one of these ecu's. w.a. Is finally getting e85 at one station. If I get some id1000's, fit a walbro e85 in tank pump, will this ecu be able to have 2 tunes on board, one for e85 and one for bp98 because I don't think I'll be able to rely on the one station to always have e85 avaliable ?
basically, i will explain to you what that answer means....
you can buy a sensor and put it in the fuel line, and it detects the ethanol content in your fuel lines and the ecu will adjust the tune accordingly on the fly, without you having to do anything really.
all you do is just put whatever fuel you can in the tank and the computer does the rest. does not matter if you only have half of e85 and half of 98, or a quarter of e85 and the rest 98, the ecu will sort it out for you without you even knowing.
thats appealing. will the car be tuned at its best potential then? does the tuner define what values of timing is set for 90% ethanol to 5% ethanol then the ecu scales accordingly?
and then if i was runnning premium 98 fuel mixed with no ethanol fuel at all it would be a completly different map?
i guess what im trying to work out is do i give the car to the tuner with e85 in the tank, get the car tuned, then drain the tank fill with bp98 tune the car again, then there is 2 different base lines to work with?
cheers
Edited by jamesdt
Yes, you would normally get 2 completely separate tunes done - one at 0% ethanol and the other using 85% ethanol (and I mean actually 85% ethanol, E85 can vary in content).
The ECU then reads the output from the ethanol content sensor you install and interpolates between the two maps - so if you have 40% ethanol content in your tank currently then your ignition timing and fuel injection would be halfway between the two tuning maps.
That's a simplified version, anyway :)
Spoke to the tuner that I'm dealing with and his advised against going the ethanol flex sensor. He would much prefer to have two separate dedicated maps and has pushed away from using an adaptronic select, he did say tuning them is more difficult and they don't get a satisfactory result when using them. That's probably just in experience of tuning them... they advised on using a vi-pec plug in ecu. I'm guessing a v44 model would be sufficient enough over a v88?
*sigh* sooo many tuners blame the ecu on their poor tuning skills.. it pisses me off. the vipec plug in will do the job the same as the adaptronic, but it is far more expensive.
the vi-pec plug ins now come with a v88 top board, which means they are fully sequential. plug ins are called plug in's. they are not called v44 or v88's.
  • Like 1
Would love to try an Adaptronic, amongst other ECUs out there. People here even bag Links/ViPECs for their results - again, ultra suss that people blame their tools and annoying that they somehow manage to get the benefit of the doubt.
sounds like flex fuel and tuning a different ECU are above his abilities. that is the nicest way I could possibly put it.
Get a new tuner..
So 440 Universal or Link G4 Storm for a built YB Cosworth with about 460hp A bit gutted to be changing the Pectel ecu but need something with more accessible software for some more mods and tunability
whats wrong with the pectal? dont buy an ecu till you talk to me i have something very special about to surface.
    • I just got this system but haven’t installed yet I got a Moroso sealed box (defect reasons) which will be set up same as their pic The quality is high grade, the correspondence I had with the owner (former head designer for Rockford Fosgate) was unbelievable, guiding me with what I needed. Even told me not to buy some things as it could be sorted in a different way at his loss. Just a bit of a bite with the exchange rate and don’t purchase gear in 1 hit that goes over $1,000 au, lol I forgot!
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I eliminate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for? (Apple car play? Android air play)? so If I swapped head units to save using a band expander, I’d likely lose those better features to have an oem Unit operational. Better to use a band expander and retain AirPlay options and newer version of head unit     provably best to band expand it, and focus on the nav unit. th isn’t  a big deal/ would be cool to have it working  from what I can tel we use a PAL Signal and Japan uses a NTSC signal  I don’t know if there’s a co better or if the screen only reads NTSC, or if it’s the tv module that needs replacing… no big deal don’t need it but more of a curiosity thing on that!   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
    • That ring thing is interesting how it's holding everything together
