Ryno: I have heard good things about them from a couple of tuners, however.... trent hates them with some interesting passion.....
Trent: a workshop i tune at here in the UAE, purchsed 25 Wolf 3d units a LONG time ago, and they got 23 of them left brand new old stock ready to go.... but the issue is that they won't go... nobody wants them even when offering them at half the cost price!!
trying to find support and info on them is proving to be a mission, i gave up trying. i think they have gone bust?
My Tuner uses Wolf V550s as often as he can, I actually dont like the idea and plan on going with a E1280S based on the previous success I have had with a E420D. I have the dreaded timing jitter and a power FC so I am going to run a crank trigger set up.
Has any one here had any experience with the E1280S Yet? Any thoughts on the E1280S would be great.
Cheers!
what happened to the 420d? they are pretty much the same ecu as the select plug ins are anyway ???
the 1280 is the super ecu... i have used them, they are great but very advanced and setup is not as easy as the select range.
if you get timing issues you should try and run one of pauls trigger discs first, but that requires removing the power fc because they only support oem trigger mode.
Half cost price eh?
hmmmm
The e420d was in my sil80. I no longer have it. Have a r32 GTR now. I don't love the idea of non sequential ignition and injection hence the 1280 idea but I do note that you have had no issues so I need to think more about and perhaps get a select instead.
One way or the other the power fc is going. I have had nothing but trouble with it. If you think a different trigger disc will help I suppose it's worth a go. It's the cheaper option.
Thanks as always for your input mate!
  • 4 months later...
Looking at getting the e420d, on the website it seems the plugins come with base maps, but no mention of getting a base map on this one. Can you download these or is it fairly straight forward to set up without?
Is it possible to still buy new plugs and terminals for the engine loom? or do you have to reuse the old ones when making a new full loom?
cheers.
there will not be a base map on the 420, because its a generic wire in ecu and can be installed on any engine. However when making your order you can tell them what engine you are running and they can email you a base file for that specific engine.
I find that Andy has a start file that can start pretty much anything, and the times that he did not have a file he made one for me within a day or so. even if the trigger mode is not supported he can make a quick firmware upgrade for you quickly as well!!
The support is great. the guy is the ecu professor, you don't have to worry about base files when buying an adaptronic.
I accidently ripped out the usb plug from the ecu board and damaged it. I contacted adaptronic and he offered to send out a replacement top board in advance to get me up and running...
it appears that getting the car back on track was more or a concern to them, no hard warranty claim procedures or its your fault or my fault bullshit that you would normally expect, i even told them i personally broke it... cannot believe it.
Bunta, go with the Select ECU. It's a great ECU for the price, and unless you need/want the super advancement of the E1280S, the Select ECU is really what you want.
I ran the E420C (With one of the very first few plug in looms for my R33) and never ever had an issue due to it being sequential.
Oh and you can't beat ease of installation! Run one vacuum line to inside the car, unplug old ECU, plug in new ECU, plug in vacuum line you just ran. Send car to tuner.
I ended up with a link g4 at a price I couldn't pass up, however I would not hesitate to go adaptronic. When we had trouble with the adaptronic in the sil80 Andy himself was in brissy and drove 45 minutes out of his way to check it out personally. Service with these guys is really second to none.
he drove out to see you ?  hahahaa..  lucky you.
he does go out of his way to visit special projects.
Yeah he drove to the work shop to check that the ecu was functioning properly! He was probably just sick of us ringing and asking guestions. Lol
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
