  • 3 weeks later...
Yep it is red mate, and it has the touch screen Navi on the oem screen too - so I assumed you had a hand in it Chris. It is in Perth now - did you do it in Qld or did he fly you over? Also, did he get the km lined up, or are they out?
its a perth car. when I did it the car it was landed/complied in brisbane and modified here by me.
KM is correct. I had a local instrumentation shop reset it.
the car waas dropped off to me customer paid me money and I did stuff. :P
geez you're sure tight lip about everything :P.....if i get one in again, ill make sure it goes through Brisbane. Will call you if anything
look at it this way do you discuss what you do for a living in detail on a public forum :) ? I tend not to given most know that I work on these cars for a living and it how I pay my house loan and other expenses.
put simply - its doable and I can do it :P I will answer certain questions but how I do things is not one of them.
Ah that explains why you haven't replied to my emails chris. Are you saying that you want money to help someone?, you know my situation (i'm in NZ) how much $ would you need?
got busy actually . will send off a full quote once I get home to a pc. low mid 4 figure though.
I think what a lot of us fail to realise is that Chris is an Auto Lecky by trade. It's what he does and what he enjoys doing. At the end of the day, he built his knowledge through years of servitude to the industry. He knows his stuff because in an industry fuelled by clients not wanting to pay decent dollars and companies offering crap services for minimal fees, the guys with the best knowledge and most innovative are the ones that stand out from the pack. He's a master of his trade and we can't just ask him for freebies. He built his intellectual property and shares a lot more info about what he does than most do about their day to day jobs. Let's give him a break eh?!
Well said, t5iv. People seem to fail to realise that not everyone here is just a general member of the public and/or enthusiast.
If someone doesn't want to divulge their secrets for whatever reason, be it on the basis of profession or just simply not wanting to tell, then respect it and do the same homework they've done. We all learn from experience so if you don't find the information you need, make an effort to figure out the information yourself. Grab schematics, find old junked out gear and if you're really ballsy, make carefully calculated tests with your own vehicle. If something breaks along the way, be sure to have the cash around to fix it. :)
Thankfully the firewall grommet ring that I broke only cost me $7 but I bought 2 just in case I'm an idiot for a second time. :P
    • Turbo gods, some assistance and recommendations please I'm looking into a turbo kit for my 2.5 from MX5 Mania >>>>> https://mx5mania.com.au/products/copy-of-mx-5-nc-2-5-litre-engine-conversion-turbo-2005-2013 Power wise I would like about 200kw atw, and of course dose noises, apparently if you keep a stock 2.5 under around 200kwatw the engine and drivetrain will not hate life even when ragging on it a bit Max RPM on the 2.5 is around 6500rpm The turbo MX5 use is something around the disco potato size as  packaging room for the turbo is pretty limited, which will, I believe, give me my power goals I want and not have the turbo either under, or oversized, but the rear housing bit is confusing  It comes with either a 0.64 or 0.86 From my understanding, which so far is based off googling, so make of that what you will 0.64: spools faster = good Makes more EGT heat on boost = bad Less topend power than 0.86 = I'm only looking for 200 atw so that point may be mute????, I don't know, hence my questions  0.86: Spools a "little" slower = how much slower??? remembering 6500 is my max rpm Makes less EGT heat = good Makes a little more power up top = again, power goals is only around 200 Also, this is a street car, so there will not really be any long track sessions, in saying this I would want it so it was happy with at least 3 hot laps at Wakefield Park if the need arises  I already have a fancy pants triple pass radiator, and a oil cooler with thermostat will be getting installed as well Thanks for any information or recommendations you have 👍, and of course, the comments about me wasting money on drive in drive out modifications, or any other snide remarks about my manhood for owning a MX5 🤣
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
    • It is possible to do this stuff for "cheap". But you need to be able to get deals on all the bigger items, and it really helps if you're fully capable of doing your own work. As soon as you're paying retail for new parts, or buying "kits" because you can't fabricate necessary bits and pieces, and if you really need someone else to take the reins of doing the work because you don't have the space/time/skills/confidence to  rip deep into the car and put it back together in a working fashions.....then you pay. And these days, pay means a lot of money. You'd think things would get cheaper, but they don't. They just seem to keep getting more and more expensive.
    • It’s almost the price of an engine build, you won’t have anything to bolt onto it though
    • Hopefully it's enough to help with the temps! I was also only shit stirring, regarding Murphy's Law basically. I've found, what ever spare parts I have, are the parts I don't break. Ever. Also have never had issues with oil/spinning bearings until I put oil pressure gauges on the car. 😛
