Its just out of fashion
you are a bullshit artist if you think it did not look cool when you first saw it
New fashion is hella flush bro
if you want some cheap decals
Sand your car back to the metal put salt and beer on it
Cheap and in fashion :D
  • 2 months later...
How much did they want for the installation?
One is saying $70 an hour and about 4 hours but knowing them they will prolong it to 5 hours or some shit
The other is saying $90 an hour and 3 - 4 hours but depending on what type of vinyl it is depends on how long it will take.
Why don't you try to design your own, make a stencil and use plasti-dip and spray it on. If you don't like it just peel it off.
Plasti dip is terrible..... it will come to washing my car and the sponge would just wash the plasti dip off with it
Since when!! I know a few people that have done their bonnets, rims and badges. No issues like what your saying. And they are all over a year old. I think it's a bit of a myth.
Agree. My brother has got bits and pieces of it on his car and not an issue yet. It is surprisingly really good and easy for that DIY stuff.
For F**k sake someone delete this thread. Plasti dip WILL NOT wash off with a sponge unless your washing your car with sand paper or some shit.
f**k me!
Plasti dipped rims before, you knock em a little bit with the lug nut and the whole thing starts to shit itself and peel off, i.e you get brake dust all over it it does not wash off without bits coming off
You did it wrong lol. How many coats did you do? Also... because plasti-dip IS durable.. you can scrub them with a sponge and soapy water lol
I dipped my rims a year ago, a few weeks ago, it took me 2-3hrs to take the dip off on one wheel....
this!!!!!!!!!!!!!!!!!!
3 - 4 coats, first 50% coverage, 2nd fill, 3rd full coverage, 4th extra
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
