I'm looking at putting an aftermarket rear diff into my car and throwing the standard "A-LSD" in the bin. From what I can gather, I need all the Non V spec gear to make this work but what EXACTLY do I need? Does anyone have a part listing so I can go and get it?
I assume all aftermarket diffs require the same thing wheather it be a Nismo, Tomei, Quiafe.
yeah it ends up being quite an expensive exercise..
you need the non V-spec diff housing and shafts,
then obviously your aftermarket centre of choice.. I went the Nismo GT-Pro 1.5, not as street friendly as the A-LSD, but you know its locked when you need it.
nothing else special required..
Thanks Tricstar. That's exactly the info I need. How do you find the Nismo? I was looking at putting a Quaife in mine which have only just been released. I have one in the front and love it to bits.
Did you get your non v spec stuff second hand? If so, what sort of coin did it set you back?
Michael: Were you still interested in a Quaife rear?
Yes, have it sorted. Send me an email if you want to discuss.
Bare in mind I'm in Perth, so everything is more $$
Got the diff and shafts from a Jap importer/wrecker for $850 o-:
nismo GT-Pro $1400
diff set-up etc $450
replace boots on shafts $150
also did wheel bearings $800
and did the install myself $0
like ever job, theres always things you don't think of..
I do find the GT-Pro quite aggressive for the street, skips and clunks when cornering slowly. If the Quaife rears are like their fronts, I think it could be a good option, I know a couple of guys over here using quaife fronts and they seem pretty good the way they operate.
Yeah fair enough
I got a mate to price up shafts and housing from his mate in Japan. Came to just under $1000, which seems pretty good considering what you paid.
Yeah, I'm very impressed with my Quaife front. Just plant your foot and point, it's rediculous!!! Definitely makes you realise how bad the standard setup is!
Non v-spec diffs and shaft come up in the F/S fairly regularly but go pretty quick, but generally only around the $600 mark.
yeah I got a OS Giken 2-way up front, wouldn't know it's there until your hard at it, then its point and hang the f##k on..behind a 2.8L also ;)
Isn't it funny. The V spec was the more expensive car but in the end you rip out everything that made it a V spec to begin with!
Argh... Quaife or Nismo 1.5 way. :\
If it were me, I would go Quaife for a streeter in an instant. Probably for a track car as well unless it was a very serious track car.
I put an S15 helical into my R32 and it is much much nicer than the old VLSD. You'd not know it was there except that drive out of corners is so trouble free and positive. The only hassle with them is they are effectively open with one wheel in the air. This is only a problem on the occasional driveway entry and so on, and also on a track where you may have stiff enough suspension to cock a wheel, or if you abuse the kerbs.
Ahhh... now I know what you wanted to call me about :merli: (below might answer it, but call me anyway lover :wub:)
As Richard said above.
Although you can use the V-Spec shafts - it's the joiner/coupler thing (I dunno the technical name) that is actually different length so if you can find JUST the diff it can work out a few hundred cheaper, but most people won't sell without so its a moot point.
On the lowest lock setting for the Nismo, as recommended by RP, mine would clunk a little but if I wanted I could've just added some Penrite friction modifier and get rid of it. I didn't care though as it was not really a problem for me.
I loved Nismo GT Pro front/rear combo and would do it again if i purchased another GTR (right after taking off turbos), lift-off oversteer and 4WD powerslides FTW. Always locked when it needed to be so it was 100% predictable every time. It was like having a RWD and 4WD car rolled into one, hard to describe.
Only "issue" was trading 4WD hellis for 4WD powerslides. Car refused to helli with Nismo front/rear & the RP spec Tiens no matter what I tried it just hooked up, so a good "issue" to have :)
  • 1 month later...
not much really, just the line between pump and diff. and block the outlet with a bolt.
its the same pump and computer that runs the ATTESSA so all must stay.
Quaife or Nismo ?
Ah sweet!
GT PRO mate. :D
  • 1 month later...
    • Cool to see you're on the forum man, think you've met my twin brother a few times (Brent).
    • Yeah everyone always seems to refer to them as S13 wheels however they came on R32 Skyline, A31 Cefiro, C33 Laurel etc., and also came polished diamond cut or painted depending on the model. Congrats on your GTS purchase! I'd personally leave it NA.
    • In this thing about this 100% renewal energy stuff I hear no one really talking about anything other than power and fuel really Power and fuel, whilst being a huge part of how we use the billion year old Dinosaur juices, are only 2, of the probably thousands of things that we need to use it for in the chemicals industries for making nearly everything we use nowadays I'm all for a clean planet, but if we want to continue to have all the day to day appliances and stuff that we rely on everyday we will still need fossil fuels Whilst I do love science, and how it can bring innovation, there's really a limit to how far it can go in relation to "going green" As for EV's, unless your charging of your own solar panels, it isn't helping the environment when you consider the the batteries, the mining processes required,  the manufacturing process required, and how long a batteries (read: the vehicle) lasts long term If I was supreme dictator of the world, I would ban the use of sugar for fizzy drinks and food additives and use that for ethanol manufacturing, petrol engines would be happier, and people would be alot healthier  Disclaimer: Whiskey manufacturing would still be required, so says the supreme dictator of the world Same same for all the vegetable oils that get pumped into all our food, use that for bio diesel Disclaimer: the supreme dictator would still require olive oil to dip his bread in This would take some of heat off the use of the use of fossil fuels which are required for everything we use, unless you want to go back to pre 1800 for heat and power, or the early 1900's for plastics and every thing else that has come from cracking ethylene  Would I be a fair and just dictator, nope, and I would probably be assassinated within my first few months, but would my cunning plan work, maybe, for a while, maybe not Meh, in the end in an over opinionated mildly educated arsehole typing out my vomit on my mobile phone, which wouldn't be possible without fossil fuels And if your into conspiracies, we only need the fossil fuels to last until a meteor hits, or thermonuclear annihilation, that would definitely fix our need for fossil fuels for manufacturing and power issues for quite some time  Meh, time for this boomer to cook his lunch on his electric stove and then maybe go for a drive in my petrol car, for fun
    • It really helps that light duty vehicles have absolutely appalling average efficiency due to poor average load. Like 25% average brake thermal efficiency when peak is somewhere around 38% these days. So even a 60% BTE stationary natural gas plant + transmission and charging losses still doing much better with an EV than conventional ICE. And that's before we get into renewables or "low carbon nonrenewable" nuclear which makes it a no-brainer, basically. In commercial aircraft or heavy duty diesel pulling some ridiculous amount of weight across a continent the numbers are much more difficult to make work. I honestly think in 5-10 years we will still be seeing something like the Achates opposed piston diesels in most semi trucks running on a blend of renewable/biodiesel. Applications where the energy density of diesel is just too critical to compromise. CARB is running trials of those engines right now to evaluate in real world drayage ops, probably because they're noticing that the numbers just don't work for electrification unless our plan is to make glorified electric trains with high voltage wires running along every major highway and only a token amount of battery to make it 30 miles or something like that after detaching. Transport emissions is not insignificant especially in the US, but yes there's a lot of industrial processes that also need to be decarbonized. I agree the scale of the problem is pretty insane but EDF managed to generate ~360 TWh from their nuclear reactors last year and this is with decades of underinvestment after the initial big push in the 70s and 80s. I don't think the frame of reference should be solar-limited. France is not exactly a big country either. Maybe it doesn't work everywhere, but it doesn't have to either. We just can't live off of fracking forever and expect things to be ok.
