I'm wanting to start tracking my r33 what suspension upgrades do I need to do. I already have bilstein shocks with lowered king springs. Also have whiteline swaybars front and back 24mm with the end links. What arms castor rods bushes ect do I need for a decent track setup. Brands would be a help to. The car will mainly be tracked at winton as I live in wangaratta.
Cheers Josh.
https://www.sau.com.au/forums/topic/420499-r33-gtst-track-suspension-setup/
Thanks gtsboy. I've got a rough idea of what I need. Just wasn't sure on which brands are better ect and tried searching with not much luck. Also wasn't sure on exact settings. I'll try searching again. But thanks for the heads up.
Forget brands and other little mods. The biggest thing that will make a difference to your track time is tyres and driving training.
Otherwise if you still want to hash over this topic in this thread then you might want to mention what ur spring rates are in your coils as well as any adjustability in the shocks...
-GL n otherwise spend alot more time searching. Work out what camber, toe in, balance etc is and does, and you will also be able to understand alot more of the advice that will be made.
  • 1 month later...
Over the last few years we've taken an essentially stock R33 GTST to Winton and gradually upgraded it, noting the laptime benefits of each upgrade.
We reduced the weight significantly, (probably around 200kgs removed), ran the same boost pressure and stock brake system during this period. We also installed a VideoVBOX system to properly understand what was happening.
Whilst this car had previously had Tein Street Springs installed it still had some pretty rubbish standard shocks. So no coil-overs...
Biggest 'feel' benefit was a proper fixed back race seat. Not a lot of lap time here, but major gains to help learn what the car was doing.
Sway bars: -2.1" per lap
Whiteline Blade Adjustable, as most people attest, gave a massive laptime improvement on the same rubber.
Brake reconditioning: -2.8" per lap
Still the stock brake rotors, re-machined, Ferodo pads, Dot 5 fluid and new seals all-round.
Semi-Slicks (Toyo R888's) -5.58" per lap
We also shimmed up the diff a little before bolting these tyres on so it's difficult to tell how much of which was of benefit, but I can tell you the diff shims were very cheap and the tyres, not so much!
There's a million other little upgrades on there, like a HICAS lockbar and undertray, rear wing, but there's no way for us to directly prove the benefits using the data... and asides from the lockbar they aren't 'suspension' related.
We will have BC ER Coilovers on soon, but also a completely new RB30DET good for well over 500bhp and a roll cage, so it won't be a fair comparison. But I hope this helps.
Some more details on the project including on-boards etc here:
http://droppingthehammer.wordpress.com/
Best of luck, hope to see you there soon.
    • I don't really know general street pads too well, but there is no reason you can't get a low dust, long wearing, no squeal pad that works for those calipers at a reasonable price....they would just be a low end to medium price daily style pad.  If new pads don't have much bite or they loose it over time, it is probably just the pad glazing up which you can fix by giving them a good thrashing every now and then (or get the mechanic to deglaze them at next service) Track or semi track pads are where you have to put up with excessive dust (and potentially squealing as a side effect of that) in return for good bite and performance when very hot. Street pads have nothing like that sort of punishment, even long downhills with the brakes on are easier than a track session
    • lol yeah I'll check that, reminds me of the LDV thread!  I don't think that is the problem here, the starter doesn't even solenoid click. I did do a super quick test by removing the starter motor's power cable from the engine bay fuse box and the battery voltage was still 10v, so something super fishy is going on. BTW here is a R33 fuse box table I threw together from a few sources....use at own risk! R33 Fuse Box and Sources.xlsx
    • Johnny's approach, throw all the Nissan electronics into the trash. Best thing I've done to my shit box, go DBW.
    • Sounds like the JAX guys must have installed some really awful pads, are they BenShit/BenDicks pads by any chance?
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
