I know it aint much but I'm only saving bits at a time and just getting into modding it.
I know with this amount I could get a FMIC
OR I could get a power fc w/ tune.
My current mods are
R33 Series 1
3" exhaust
turbosmart dual stage boost controller (7psi and 12psi)
turbosmart bov
the car has done 110,000
what would u suggest with this small amount of money, I'm leaning towards the powerfc just to get my fuel consumption down! i'm only getting about 320-340 kms out of a full tank and thats drving like a grandma.
if you can suggest other mods that would be better in this price range or as a starting point that would be great.
https://www.sau.com.au/forums/topic/42053-what-to-do-with-1500/
For 1500 you will get a PowerFC and hand controller. What you wont get is a good tune. If you buy the PowerFC, start saving again for the tune which is $450+.
I was thinking that with $200 left over (P/FC's are going for around $1,300) then selling the stock ECU should basically fund the tune.
definately recommend the Front mount for the following reasons.
By dropping the intake temps you will be better protecting the engine (cooler intake temps = less prone to detonation), and gaining power at the same time.
The stock intercooler is not a very nice thing. Especially when you start upping the boost, showing pretty huge pressure drop. This means the turbo has to work pretty hard. horsepowerinabox have published test results wich show up to 7psi pressure drop on the stock cooler. If you have 12 psi at the plenum, your turbo will be pushing 19psi at the outlet. The stock turbos dont like boosting too hard, and doing so can cause the exhaust wheel to seperate from the shaft. A good cooler will mean you protecting the turbo too.
Protect things before you start pushing. A tune for $200 probably wont be too good. For a good tune expect to pay around $500 up.
There are people on here that get good power with the stock ecu, up to 200rwkw, so dont immediately believe you will get better results from a power fc than a good cooler.
Good luck
Whats a good intercooler for that type of money?
I notice on ebay there are some for $850 with piping 600x300x76. Probably dodgy tho?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...2479801725&rd=1
I messaged the guy and he said they were for gtst's
then again i could get a genuine hybrid with piping for about $1200
200-250rwkw is probably my aim down the track, what sorta mods would i be looking at for that?
$850 Thats a very cheep intercooler kit. Id like to know more about them. If you got that intercooler you would be able to afford a SAFC as well. Not as good as power FC but it would still help your fuel ecconomy.
munna, i emailed one of the people who had previously brought this kit and they said that they got all the parts needed and it looked good. He hadn't had any tests done on it tho.
I emailed the guy who is selling them and he said they are very similar to a hybrid and are capable up to 500HP
i have a hybrid fmic kit on my 33gts. payed $1200 which i thought was a bargin for a full polished bar and plate anitercooler and polished piping. They say they are good for up to 800hp with only a .2 psi boost drop through the cooler. As steve said i would recomend getting a cooler kit before a pfc
im dont have alot of knowlege on th SAFCII but id say it would be able able to get close to that figure on standard turbo. prob more around 180 - 190.
im runnig a wolf 3d but it is yet to be dyno tuned but am hoping for around 200 or close to it. I use to have an rb20 in a VL commodore with wolf 3d so i took the map from that and downloaded it to my new wolf and just changed a few things, knocked back timing and bit more fuel seams to go better then my old VL. Just trying to save for a final dyno tune
Front mounts are easy as to install... The hardest part would be trimming the front bar to fit the cooler.
I have added an FMIC and a PFC to my car. I think that the PFC is the better mod. Gave me a much better power curve
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
