Has anyone made or attempted to fit an air break on their car?
Im currently in the planning process of putting on on my RB25 GTS-t which has 549bhp, but im putting an RB30 in with a lot more power and brakes can only do so much. Im using hydraulics to raise and lower it, but I want be able to manually/speed adust it for higher speed corners to help with cornering.
I will try to put up pictures when I start the project.
Thanks
https://www.sau.com.au/forums/topic/420533-rear-spoiler-air-brake/
Interesting. Have you drawn your designs or just see how you go? I guess it will need some sort of fail safe, if your really depending on it to supplement braking into a corner and it doesn't activate, we'll you know. I think it's inherent design should be on/open (as in activated for braking) so if it fails it slows you down rather than doing nothing. Now having said all that are you sure that the time and money involved isn't better spent on say tyres suspension and brakes.?? Plenty of really fast cars get by without these. Also these can be bought of the shelf.
Good luck
I actually wanted to do that for my Uni project. You can either write a programm that would sense changes in G forces to activate it in terms of lifting it up when cornering. Another option is if you can get access to the circuit that triggers the brake lights you could put hydraulic pistons that would be lifted when the brake lights are engaged. When you disengage them you might need some sort of digital capacitor with enough voltage to drop the spoiler down after you let go of the brakes. As for higher speeds if you have a digital speedo you can log the circuit to open once you get to that speed.
The reason why i dint do it was the cost. You could spend that on a crazy big brake setup and custom suspension work.
P.s you might want to calculate the drag coefficient that your air brake might create and see if you get much stopping resistance out of it. But otherwise or the satisfaction of designing that would be awesome.Defs you should have some pics man.
Well im going to be using a small 2 ram hydralic system that was originally off a small convertible car. Im still in two minds as to wether to use a large flat (bootflush) drag style spoiler, or the high drift style type. Someone mentioned about using a pressure switch on the brake pedal. The sysrem from the caor uses a two way 3 wire switch that raises and lowers the roof. Im thinking of using a lever to raise it faster. I'll try and do a drawing of what im looking to do with the bits i've already got. Been thinking of doing a similar system for a front splitter which would push the splitter forward and down at speed. It would help with speed ramps too as my car is pretty low and catches most things on the road.
The system only weighs around 8-10lb, the pump is about 3" diameter and 8" long.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
