RHD Japan for genuine ones (recommended as they have clips which make it easier to install)
or
Just Jap FRP where you will need to get them painted
Also, what color is your front bar?
Because if you get the genuine N1 slots they already come white in color so you do not have to paint them
There is also the Nismo version N1 slots which are actually different (not sure how but could just be the color)
https://www.sau.com.au/forums/topic/420584-n1-slots/#findComment-6767432
Can anyme confirm that the 32 and 33 N1 vents are different? It looks like the 32 ones might have a slight bend in it whereas the 33 ones are straight? And if possible anyone know the sizes of them?
I wanna put them in my 34 bumper just not sure if they'll fit or not
https://www.sau.com.au/forums/topic/420584-n1-slots/#findComment-6769641
    • My crystal ball says that when they replaced the pads, they didn't replace all of the brake hardware (could be a missing shim, pin, spring, etc).  Finding a low dust pad should be very easy. Have a google for things like, low dust / soft pad compound / easy on rotors. Your dust primarily comes from the rotors getting eaten up by the pads.
    • I think old mate is going to continue to hold out for awhile at that price
    • OBD1 is a catch-all term for pre-OBD2 which could have basically any connector design and protocol. I really don't understand this attitude against using data logging for issues that can be multi-causal and subtle. A no-start situation or something like that sure the scan tool does nothing but if it runs like shit it can often be a sensor issue. When a friend of mine reliably had issues with his N54 not able to stay running eventually I narrowed down the issue to a faulty fuel pressure sensor. Only way I could do that was a scan tool to look at the fuel rail pressure and see shadow codes for fuel pressure. Then check against a pressure gauge. Is reflexively firing up the data logger probably a bad habit? I guess, it can encourage people to not listen/observe but on these old OBD1 cars just taking a log really doesn't do anything by itself. You still have to synthesize everything you know and think about what it all means.
    • https://www.carsales.com.au/cars/details/1999-nissan-skyline-gt-r-v-spec-bnr34-manual-4wd/OAG-AD-24005316   i reckon some former Skyline owners are wishing they held out a little longer before selling up?
    • Yeah saw that video on YouTube. But he got a R grade (repaired) high mileage model and proudly advertised the fact it was super cheap and no doubt with issues. I wouldn't be going the cheap and nasty route.
