You don't seem to get the big kick that i get - but top end is not that much different - but when I look at the rev range - I seem to get more down low...
But Doughboys boost curve looks a little...umm.... doughy. A bit like my boost response. :Oops:
B-man... do you have a graph with the boost on the right y-axis? I think you will find that with the smaller exhaust housing that his mid range will kick the living hell out of the rear wheels once the thing ramps on to boost, then holds boost properly....
  • Replies 70
Matt - the rears.. well they spin ... I'm getting the hang of ....WOT, back off, then WOT again - to keep traction (even with semi slicks)
Roy - I did have that graph, but no longer - I can get another print out but I did keep the numbers:
Boost starts at 3000
3500 = 5 PSI and 80 rwkw
4000 = 8 PSI and 112 rwkw
4500 = 20 PSI and 200rwkw
5000 = 23 PSI and 260 rwkw
5500 = 22.5 PSI and 270 rwkw
6000 = 22 PSI and 310 rwkw
6500 = 21 PSI and 323 rwkw
It's sorted. After another 2 hours on the dyno it's got some very different figures...
Sorry no dyno graph. I am so tired I forgot to take it, I think I left some tools there too. That 300kw run was never to be repeated, I think that came about by spiking the shaft speed late, by fattening up the midrange it took 20kw away from the peak.
Having said that, it's got 280kw from 5500(?) to 7500, flat as Kate Moss. It couldn't make over 1.2 bar boost up in the rev range, spiked at 21psi @ 5000ish and tapered off as it kept going.
I'm a bit fuzzy so the rpm's aren't exact. Will get the graph to compare, but Brendan the larger -> the more potential. There's no way the .73 could keep up with the mighty 1.12!
Glad you got it sorted Chris - I wasn't meaning to compare as if to compete mate - Just curious on the power curves that's all. I find it really interesting looking at Dyno graphs - especially when boost and rpm are plotted - it really makes you think about stuff.
I think it could be the tyre situation!
the cops pulled me over and said that my back tyres are bald so i popped the bonnet and showed em the 2 brand new ones in the boot and said that it was hard to find a place to fit 18" tyres but i found one that could do it on Monday, she was female and fell for it :)
Evan
Disclaimer: As I posted previously, after getting 4 hours sleep per night over a week I was in no condition to remember alot of finer details regarding output.....
This is the condition of tune my car was in from 12:30am Sat morning, and ran a best of 12.09 @123MPH.
How d'ya like them apples?
I got alot of help and asked a ton of questions, both Brett + Adrian gave me some useful tips.... well actually Brett's tips on burnouts made me stall the car, but I appreciate them all the same :O And his tyres :)
Edit: I know it's a lame excuse, but I went from 2nd to 5th in the 12.09 run.. so maybe it has a bit more left in it before I change a few things.
Just goes to show, huge peak power isn't needed to run very fast and quick numbers. Well done! The power curve from from 5500rpm to 7000rpm is bloody impressive. That would most certainly help with mph, and ET for that matter.
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
