Hey guys in in the market for an exhaust but would like to get a data base of stagea exhaust system
State your car, engine and system as below,
S2 C34 RB25DET
Stock dump>gutted cat>stock mid muffler>blitz rice maker muffler
Keen to see what others are running and discuss what performs better. Personally I think local custom is the way to go, the Jap stuff is just too expensive for what it is.
Post up your system!
https://www.sau.com.au/forums/topic/420592-your-exhaust-system-post-your-setup/
Can you state your desired power output also as this will have more impact on the noise and expense of any system you require.
For stock power the stock exhaust is the pick, with a decent front/dump.
Most aftermarket Jap systems cant be beaten on noise V flow.
As much power as possible is always the go isn't it? Haha not too fussed on loudness too be honest just after people's system to gather information etc what do you scotty? Another thing, stainless steel vs mild? Best sizes? Types of muffler for best flow?
Well if its auto, you will worry about loudness, as they drone about 50 times more than the manuals, and are excuriating
to stay in, if its manual, just get all 3 inch and fart cannon and thats it
C34 :
I've had dump, no meow, full jap n1 fart cannon system, no mid muffler. 3 inch .., coudn't stay in it for more than 20 minutes without wanting to kill somebody due to drone , on the upside ...sounded like angry GTR on fullnoise even if it was slow
then mid muffler..no real friggin difference, had to drive to melbourne with earplugs in, as the drone is worst at 100km, mid muffler now shits me as its lowest point of car and always scrapes on speed humps
then mid muffler and chambered muffler necked to 2 1/2(not my friggin doing)..ultra quiet(to quiet)
Atm going 38mm ex gate for full throttle noise, and check on dyno if chambered muffler kills
power with 38mm gate. If it does will fit a boost operated solenoid with flapper valve after mid muffler to open under full boost , if it doesn't kill
power, i will just remove mid muffler.
cheers
darren
Edited by jet_r31
Locally made 3" straight thru including 12" oval mid muffler and a monster rear can 18" fat (cbf going out to measure it) dead quiet and still makes plenty of power. It is quieter and better than a Jap system with no sneaky steps down in diameter inside some Jap mufflers.
The best size is a 5 inch sidepipe, but we need to compromise for the street. Noise for the sake of it is just asking for police attention.
I run a 3.5 inch stainless system, it is only just big enough for the power I am running atm. I use a Varex muffler to control noise when I go through an RBT etc, otherwise it is actually fairly quiet at wot when open. It does drone though. I only use stainless as mild systems rust out too quickly, especially with ethanol.
I had the Varex running a boost actuator, it didn't work well though as the exhaust was too restrictive when the valve was closed. Response was affected mainly, which you don't want on an auto. Hopefully your design works better Jet, perhaps just a spring actuated flap might be a better option?
I'm not sure if i'll need it scotty, as i would be happy with 300rwkw auto, i would have thought that this system with venting
38mm external gate would do it..we will see i guess, i'll pull it of on dyno . , otherwise i will use this
http://www.spracingonline.com/store/SP_Exhaust_Cutout_3__34___Boost_Activated_/3673
after mid muffler
cheers
darren
Intake:
Apexi power intake pod filter
Z32 AFM
Metal hard pipe turbo intake kit
Exhaust:
3” JustJap stainless steel single dump pipe system (bolted to GT3076r)
3” 100-cell cat
3” cat-back exhaust system with Magnaflow mid-muffler (straight through 'hotdog' resonator) and Kakimoto GTR Racing rear-muffler (straight through)
Magnaflow made all the difference to quieting the "drone"
Ok so I removed my last stock muffler and welded a pipe in its place now it's straight thro to the rear blitz muffler. Sounds really shot and drowny now haha best muffler for drown? Still want it loud tho
Magnaflow mid resonator. ie Hotdog
get off ebay USA......
I don't think you can win, the resonace drone on a C34 is bouncing of the front windscreen and rolls in from the back, and only
affects the front passengers. If you sit in the back seat, its not there, actually if you put you head a inch back from the front seats it disappears(well did on mine). but in the front it was ear bleeding, You might have a shot with it being manual though..
I had a magnaflow resonator on back of R31, it made a difference, BUT.. i think the main problem is a station wagons a big open area, whereas a sedan has a boot area and is a more enclosed spac, i woudn't expect a R34 sedan or 2 door to have same problem
good luck
darren
Edited by jet_r31
Hotdogs or resonators do sweet FA, you need a proper mid muffler.
Im sorry, but in this instance I just cant agree with this comment ^
Speaking from experience with my Stag
without hotdog = drone
with hotdog = drone (mostly) gone.
Not talking about a decrease in noise volume, rather the sound it used to make pre-hotdog within the cabin at a constant rpm @ cruise.
I wouldnt recommend it if I hadnt seen a positive result myself.......
http://www.ebay.com.au/itm/Magnaflow-13743-7-Dia-Round-Stainless-Steel-Univ-Muffler-3-Inlet-Outlet-18-L-/380574863837?pt=Motors_Car_Truck_Parts_Accessories&hash=item589c0791dd
I had two resonators installed in mine, the drone was still there, all they did was make the exhaust sound tinny and weak. The wagon is a speaker box, and you are inside it.
The only exhausts I have heard that don't resonate/drone are the Fujitsubo Legalis and Nismo for the M35, surely there is something similar around cheap you could pick up S/H?
With enough trial and error you could weld in a Helmholtz chamber, as Fujitsubo use. It is a tuned dead end muffler, which can take out certain frequencies of noise, specifically that freeway drone.
my car came from japan with the following:
3" from the turbo
3" hiflow cat
3" into split 2.5" pipes after the diff
2 x 2.5" to 4" kakimoto hyper mega N1 mufflers
all stainless and custom made by the looks of it.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
