R32 Gtr R33 S13 Evo Bits N Goodies
Hey fellas,
Some changes of plans, some left over engine build bits:
R33 Front bumper - Trust style, smashed up a bit, good for drift/racing - $50
GTR Injector Resistor Pack, to be used with any low impedance injectors in cars that have high imp factory - $100
RB26 water pump - genuine Nissan, 10,000kms old. Perfect cond, used N1 instead, suits all RBs - $50
Gates racing cam belt, 10,000kms old - $20
RB26 Thermostat, genuine Nissan, brand new - $50
R32 GTSt Bonnet, chopped GTR style and fitted with a genuine plastic N1 lip. Total GTR appearance with no dodgy-ness. White, very straight. - $150
R32 GTR bonnet, genuine ally bonnet, blue, few chips around the edges, but very straight - $500
R32 GTR Bonnet Catch, ideal for use with the GTR bonnet on a GTSt - $50
R32 GTR Seat, bit of wear on the bolster. Cheap good seat. Comfier and better at holding than most aftermarkets. Cant be beaten for low seating position - $100
AP Racing 360mm brake kit suit EVOs, brand new rotors, brand new bolts and nuts, complete with lines, calipers, pins, hats and EBC yellow pads @75% - $2500
post-17897-0-62610900-1361789835_thumb.jpgpost-17897-0-07115100-1361789856_thumb.jpgpost-17897-0-46819400-1361789866_thumb.jpg
EVO 5 turbo, perfect working cond, no smoke, complete - $300
6 x 650cc Injectors low impedance with ally rail kit, freshly ultrasonically cleaned through Racepace, not used since - $500
SR20 S13-14 Midnightmods short shifter, used for 1 hour - $75
SR20 solid engine mounts (pair), 1 hour use - $50
More pics available on request.
Located in Melbourne, happy to arrange post/freight.
Mat.
0400 558 030
  • 5 weeks later...
 Share
    • Yes sir, that was me. Fake ARP's are also a thing over here in Canada and we only order from reputable dealers. It's sad that even simple things like bolts and hoses are now also being copied... anything to make a dollar.  Story time. Like all cheap crap from China, it's even an issue with firearms. Roughly 15 years ago, I purchased a new cheap Norinco 12g shotgun. First time out in the bush with it, while firing, bolt assembly didn't lock and it fired out of battery. The receiver also being cheap steel, basically exploded in my face. I was lucky to be wearing eye protection. Long story short, don't buy Chinese junk. Also Norinco being state run and their only military arms producer, if ever they do try and take over a country, don't worry about it lol.
    • Installed  Nismo coppermix twin competition spec last year in my bnr32 with pull trans with Oem slave cylinder. The point at where the clutch disengages/enages is right at the top of the clutch pedal, meaning I barely have to push the pedal down for the clutch to be disengaged.  You guys that have the same combo are you experiencing this high pedal bite point??   Secondly I’d like to have the disengagement point lower meaning I have to push the pedal more(further not effort)for it to be disengaged.  I’m thinking to use a Nismo big operating cylinder(bigger bore at 13/16 vs Oem 3/4) which will require more pedal stroke to get the equivalent movement at the clutch fork. But I see Nismo web site says not to mix these 2 as the Nismo big operating cylinder doesn’t have enough stroke to disengage??? Any folks run both the coppermix twin pull with Nismo cylinder??    Thanks in advance for the replies but prefer only guys with pull clutches to respond. thanks
    • Any chance u could let us know where your based ?
    • That’s a great deal and I would jump on it if you were closer. Melbourne is a bit of a hike for me though unfortunately
