hay fellas
my clutch is starting to slip !!!! and soon ill be doing some upgrades. im aiming for close to 300 kw at the treads !
i have a 98 year model gtt, what type of clucth would i be looking to buy to handle this kind of power ?
and whats the diffrence between a push and a pull type clutch how do you tell what u have ?
https://www.sau.com.au/forums/topic/420616-r34-gtt-clutch/
My excedy cushioned button was crap for higher power... Pedal was very soft and at the end it didnt have the clamping force... May have been a one off issue but i would avoid them due to my experience... Super happy with the JB
https://www.sau.com.au/forums/topic/420616-r34-gtt-clutch/#findComment-6765793
Bro go with NPC i got quotes all over town from exedy to extreme.. ended up calling NPC.. They had a chat to me, talked to me about my car, how much power im making all that.. and at the end I purchased a clutch kit off them for 775$ for a heavy duty organic.. thy reckon its good for up to 350kw-400kw ? if i remember correctly. NPC all the way man. thats a decent price man.
  • Like 1
https://www.sau.com.au/forums/topic/420616-r34-gtt-clutch/#findComment-6766944
The organic is around 330kw in the GTT i think... Either way that is a decent clutch and a decent price!
https://www.sau.com.au/forums/topic/420616-r34-gtt-clutch/#findComment-6767034
im in the same boat, using ORC twin plate atm lasted about 70 000kms on day to day, and few track days twin plate
cant choose between exceedy twin hyper or nismo copper mix twin
and yes i put out 300kw
any suggestions aswell??
oh ORC im using is solid centre damn pain in the ass to drive in traffic definitely go for sprung centre this time
https://www.sau.com.au/forums/topic/420616-r34-gtt-clutch/#findComment-6769994
  • 5 months later...
I got a quoted from npc. 1050 for 10inch cushion button clutch.
Which clutch did you get ?
I was thinking of a 6puck sprung clutch
But I don't want it to shudder !
I'm waiting on Jim berry to get back to me so ill make my choice soon.
Hardest decision on my life !
https://www.sau.com.au/forums/topic/420616-r34-gtt-clutch/#findComment-6968443
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
