Hey Guys,
I have a few stagea questions for the techs.
I have had cefiros, skylines etc but i got into motocross a few year ago so i downgraded to a old 88 triton..
recently i purchased a car i have wanted for a long time, a Stagea.
i have had it for a week today and i have a few questions for yas.
1.)Is there an over driver on and off switch for the automatic transmission??
2.) i always let it warm up before i drive, if i let it warm up for 2 minutes 30 seconds ( temp gauge goes to half way) is fine, but if i let it warm up for 30 seconds ( temp gauge hasn't moved) it cuts out??
3.) last night the AT light came on the dash and car wouldnt go into over drive, pulled over, turned car off then it was fine??
any ideas would be great guys
cheers
Kris
https://www.sau.com.au/forums/topic/420632-stagea-problems-please-helllp/
Ok so it happened again. Driving today and AT ligjt came on . So I pulled over. Instead ogf turning on and off I stopped and took off again. It was like it was in 4th and was stuck. Sounded like it was slipoing but once I got speed was fine. The dash said it was changing gears but didnt feel like it.. so I stopped and turned it off again. Now its fine again . Does this soumd like somethibg major??? Just sucks coz cant get it to mechanics for another 3 weeks
I've only ever had a S1. I don't think you guys are talking about the O/D though, but the torque converter locking up after warming up. It'll go into O/D when cold but the converter won't lock up until the box reaches temp (kind of sounds like going into another gear though I guess). In winter I can almost get home before it'll lock up. But I don't think thats the problem here anyway. I don't know if the S2's have the A/T switch to go between power, normal and snow. But flicking it in snow will make it feel like that. Takes off in second from stand still. But I'm thinking its going into a limp mode for the gearbox. So could just be a sensor somewhere that on its way out or something more sinister. Explains why when you turn the car on and off it goes away.
As a suggestion, do this:
http://www.skylinesaustralia.com/forums/topic/266512-reading-nissan-fault-codes-ecu-fault-codes-how-read-them/
Have pen & paper ready.
It should give you an indication as to what could be at fault.
Clear the codes & see what happens. Sometimes, if there is a minor hiccup (e.g. slightly ill fitting harness plug) in a system somewhere, it logs a code. Even if the hiccup disappears, the code is still logged, so it can bring the light on & depending on how bad the ECU thinks the issue is, go into limp mode, like what's happening to you.
While this sounds more like a faulty sensor, have you checked trans fluid level? I know autos can get all funky when they are low.
And for christ's sake, don't warm up your car for two and a half minutes >< You're doing more harm than good.
Start it
Let it idle for 20-30 tops
Get going
Drive sedately until it's up to temp
ah ok fair enough then...
i only let it warm up that much once, usually is about 30 seconds, trans fluid looks ok but will double check levels tongiht i guess. going in to get checked soon i hope
Taking it to a work shop tonight hopefully. they didnt have the connections to run the tests last night so hopefully they have them today.
its been fine, the mechnic told me togive it a bit and i do today and the AT light came on twice =(, i had more of a play around and it seems to come on, ans be stuck in 3rd and 4th, and when its in 4th i decellerate drops to 500 rpm, again turn it off and fine, hopefully they can source the prolem today.
Hey guys, got it scanned today and its shift s/v a psw, so the shift solenoid has shit itself.
they quoted $500 approx not including oil etc..
anyone replaced one before? i know the sump has tto come out bud dunno what else has to be done
They would have to drop the valve body to replace the solenoid, $500 is a little expensive, but they did diagnose the fault and they need to warrant their work. If it fixes the fault I guess you got out of it cheap, a s/h box would cost a lot more than that fitted...
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
