Seems to be a common problem with Rb20dets these days.
Upon cold starts my R32 the idle is rough and tends to hunt and drop after the throttle is released. The second problem is the car tends to jerk under partial throttle, almost like a surge. Upon WOT the problem isn't apparent.
Both these problems are only whilst the car is cold. They disappear as soon as running temp is reached.
I've gone down all the usual avenues. The BOV wasn't plumbed back and I did it a while ago. Cleaned AAC valve, reset ecu, changed plugs, swaped coilpack looms, changed coilpacks, cleaned AFM.
Could it be a throttle sensor problem with the second issue? If anyone has any insight it would be highly appreciated.
Edited by Truffles
https://www.sau.com.au/forums/topic/420635-r32-rb20-cold-running-issues/
Is your AAC (aux. air control) working? I've found out with several RB20s in the past people tend to block them off completely because the AAC has failed causing high idle.
AAC is not the IAV.. this is located underneath the plenum and has a hose that connects to the crossover pipe next to the BOV... these things usually get clogged up with dust from using pod filters ra ra ra and seize up. Their purpose is to feed air post throttle body by collecting air pre throttle body.
Commonly cold start issues are due to AACs not working.
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
