well took the passenger sideskirt off tonight and plan was to cut the arch then i can weld them both up the same time but i have had a 3 inch crack just above my side skirt and was thinking it cant be that bad lets see whats under it big mistake my whole rear end has been coated in filler for some reason its been plastered on it as well no wonder why this side looked different im going to cut the arch tomorrow and see what joys i find then ??? also notice gaping holes where my arches were good job i got access to a mig welder and lots of tools in my new job lol any how heres the latest pics :(
all the scraches are where the filler is look how thick it is as well
the rust will be sorted and so will all the filler before i offer the arches up
well got the arch cut out and slatted on this bad side and now ground away for welding to commence also most of the silicone crap removed from the body also took the filler down a few levels as soon as i cut the outer skin off the arch popped back to where it should of been
  • 4 weeks later...
Work has been flat out but we got it welded up one side on our dinner break cheers Martin 
Got the panel straight as I could took off old Japanese filler and ground the welds off primmered and bonded the one side one here it is held together and left 48 hours to set
Took of the masking and ended up with this
Another dinner break Welded up the other side
That night stayed on and got Welds ground off and excess cut off
3 coats of primer
Bonded on
48 hours later took the masking all off ended up with this
1471205_10153598671975273_1076575791_n.j
1460002_10153598671690273_100754631_n.jp
Drove home like this as the workshop was getting full
Waited a week and got some carbon fiber filler so it wouldn’t ever crack needs another layer
Done both sides both still need another layer to make sure it blends in nicely but got this so far bumper and sideskirts just loose in the pics for a mock up
  • Like 1
Doing very well. Really like seeing people do their own work. Make sure you really pay attention to rust proofing inside the guards when finished. Anywhere there is heat applied there will be a lack of factory protection. Are you going to use spacers on the wheels ?
  • 2 months later...
Now almost the end of February 2014 my winter project is almost done
Second hand gtr fuel flap bent and fitted to get a shape of where it needs to go
25 mm hubcentric wheel spacers delivered
Off to the body shop she went
Fuel flap made as the gtr one didn’t work as expected
Sanded down and masked off
All in paint and back home still need to go back to get the rear bumper sorted going for a different style with that and the sideskirts need better fitment as the rear is wider which is pushing the skirts out of line but got this the rear each side is now 35mm wider than stock
  • Like 2
  • 1 month later...
cheers Bud
well end of march and winter has gone and the car is 99.9% completed now my bumper i never really liked so got a new one it now has been fitted what a bugger it was to get it sitting right not perfect at the moment waiting for a day off next week hopefully I can get it bang on  any way here are the pics
10003899_10153975551655273_754166450_n.j
1965070_10153975551365273_851914118_n.jp
10004041_10153975550555273_1518773849_n.
Its been a long process as I have been in work and trying to do it dodging the rain wasn’t fun but hey its almost ready to a standard I wanted it
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
    • I used to love stock take. I used to take f**k of a lot of stock. /Rodney Rude.
