Im in the middle of changing my timing belt and cant remove the drive belt,alternator and P/S. Is there a certain sequence of going about this because i keep tightening the belt but the reverse is doing nothing at all.
Iv undone the hinge bolt pictured in the second picture. The two bolts im confusing of their functon are in the first picture.Ive undone the short belt, and tightned the long one and it pulls the alternator back essentially tigthening it. Help want to finihs this early if possible.
so i managed to take the alternator belt off by removing the water pump pulley. Anyone know where the hinge bolt for removing the A/C, Power steering is?
Would undoing the tensioner circled loosen the power steering?
Edited by B-rice
https://www.sau.com.au/forums/topic/420650-removing-drive-belts/
I'm not familiar with 34s but from that picture it looks like the power steering and ac compressor belts are desperate..
Your power steering should pivot closer to the block so you can remove the belt
That idler you have circled should be able to be loosened by the front bolt
Not sure why you couldn't get the alternator belt off.. It's just a matter off loosening off the two bolts in the picture as well as the bolt that it pivots on..
To make them tight again use a lever bar to get tension
To remove the power steering belt,
loosen the 12mm tensioning nut below the pump on the right hand side. (on a long thread). Take the nut 3/4 of the way down the thread not off.
slacken the tensioning thread which is the 12mm bolt pretty much below the pump(follow that long thread back to the underside of the pump) the bolt sits the the adjustment slot.
slacken the 14 mm nut above the pump behing the wheel, can be seen in you pic. once these are slack push the pump downwards and you belt will be ready to pull off
To do up again:
Fit belt
Pull pump up the take the tension
Tighten the tension thread bolt
Tighten up the tensioning nut on the long thread and tighten to the required deflection.
Tighten the 14mm bot above the pump.
Th alternator is essentially the same there will be the two bolts that are used to tension and 1 bolt to anchor the hinge.
Undo the nut the nut that looks like its going through the long tensioning bolt.
Undo the bolt that anchors the hinge (stops you from moving the alternator
Undo the tensioning bolt the alternato should loosen up.
I just did this whole process on the weekend twice but that was on an r33,
so to add to the above, theres two bolts for each, you want to loosen both of them, so both bolts turn anticlockwise, its the long threaded bolts that help to do the final tensioning by tightening them. the A/C BOLT is under the bottem pully wheel, so have to get under car to see it.
when reasembling it, make sure the timing belt cover is on properly and firmly or else it will rub on the harmonic balancer and sound terrible. :yes:
Edited by AngryRBGTX
  • Like 1
    • Not alot of room in the front or mid pipe to play with Helmholtz chambers, plus they are pretty hit and miss getting the length and volume right, and time is money when it comes to trial and error testing at a exhaust shop, it isn't like test fitting mufflers or resonators From previous experience with exhausts and trying to tone down the volume and eliminate some drone, a resonator in the mid pipe typically make it much better,  and even possibly stop Jackie complaining about it, me, I really don't notice it that much, but, I am pretty deaf 馃ぃ
    • I know it's an entirely different engine, but I noticed practically 0 difference removing or adding 2x 3in (5inch body) 400cell cats (one in each bank) with regards to sound. So changing the cat to change drone I suspect will have very very, very, very, very, very very minimal impact.
    • 200 cell cat will probably help. Do you have room to tee off a Helmholtz resonator anywhere along the exhaust? These can do wonders for drones, with a little experimentation with regards to length.
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30掳bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • www.rollracing.com.au tickets aren鈥檛 live yet
