i've managed to grab a few kits from japan for myself and a few friends, i bought some extra ones because half the time they are never in stock at nissan japan.
soo i have a few kits for sale.
These drop right into r33 gtr, direct no mods and fit r34gtt's(someone confirm this) r33 gts25t's with a slight mod to the accel. pedal (theres a metal support piece that needs to be cut cause the pedal is alumimnium now not rubber so its not needed)
They work with r32 but the dead pedal housing is slightly larger on r32 so there is a small gap when replaced with r34 dead pedal. This can be fixed by purchasing r33 or r34 dead pedal housing and installing that in place.
1xBNR34 Pedal Bushing
2xBNR34 Clutch / Brake Pedal Cover
1xBNR34 Accel Pedal
1xBNR34 Nur Pedal Cover
$200 plus shipping from canada which i believe is around $20 for airmail with tracking ill double check tommorrow
Also i have a stock air box that i know some of you guys neeed/want them..... i dont know what they are worth over there but ill update price in a few mins
fastest way to contact me is via email [email protected]
975aa0a6-511e-4cdc-b47e-1062d1fe9318_zps
Edited by cooke24
https://www.sau.com.au/forums/topic/420653-r34-gtr-vspec-nur-aluminium-pedals/
I'm like 100% sure it's the same deal as the gts25t just have to cut metal support that would support the rubber pedal on the accelerator. Which is no longer needed because the new pedal is solid aluminum
Shipping from Canada is $20 takes 2 weeks and unfortunately not tracked. I have a lot of interest but so far no one has sent payment. I only have a few so get yours quick
There are other shipping options with tracking but twice as much
I dont see how these dont fit, just take off your pedal, there's like a c clip and holds the rubber to the metal bit, as long as it's L shape, it will be able to use these pedals (they come with the bushing to make them fit 100%)
I have these on my s15 as well so i would imagine it would fit most nissans
Sold out. Can order more. More I order the cheaper they get. We can start a group buy that will not end up like the last one.
I have a verrrry reliable source in Japan. I will need at least 5 and could probably do $180 posted over 10 I will check
Who's in ?
1.
2.
3.
4.
5.
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
