Ok, i have now reached the dilemma of needing to upgrade the brakes on my r32 GTR
the current front set up is evo 10 350mm rotors with Evo 9 4 pot Brembo calipers.. Using Alpha Omega dog bones to make them fit ;)
Piston sizes are 2x40mm + 2x46mm
now originally i was looking at getting some R34 vspec 2/N1 rear brembos that measure 322mm, with 2 pot caliper, though these have been difficult to come by
so my second option is FG Typhoon brembos that are a 4 pot caliper with 330mm rotors, Brad from profab has dog bones that will make them fit so thats no issue
whats peoples opinions, are the typhoon brakes too big, has anyone given this a go? will they stuff up the bias of the brakes
i want to use the car for the odd track day but it will be mostly street.. and i wanna keep it all brembo btw
cheers
Personally I wouldn't bother upgrading the rears, but if you are dead keen the 33/34 brembo rears have been working fine on my race car for years. Just use more or less aggressive pads if they lock up before the fronts
To really bother upgrading the rear you need to have either removed a lot of weight from the front, or shifted a lot of weight rearwards. Standard weight distribution is about 2/3 front and 1/3 rear when static, and it is even more due to weight shift when you hit the brakes. As a result the rears do 9/10ths of stuff all.
Yes cosmetically I only wanted brembos for the rear, but if its deemed un necessary then I will leave as is
Duncan I do see your point, I haven't moved anymore weight around so I think you are right in the fact I probably don't really need to upgrade them. I thought there may have been some distinct advantage in having a bigger rear set up but if you guys reckon there's not then I might just leave them and put some upgraded pads on them
Cheers for the replys
Dont get too worried about back brakes. As long as your bias is good they will be ok. See photo for comparison. Note that with DS2500 pads my rear rotors are wearing out simply because the pads are hard on the rotors when they are cold.
I've got a big alcon kit for sale Joey haven't started a for sale thread but there is pics in my cars for sale thread sold the car without the brake kit :)
Haha thanks mick, but I just bought my Evo fronts.. Besides I've spent and about to spend enough cash lately... And I know what those Alcons are worth :(
  • 1 month later...
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
