Ok, i have now reached the dilemma of needing to upgrade the brakes on my r32 GTR
the current front set up is evo 10 350mm rotors with Evo 9 4 pot Brembo calipers.. Using Alpha Omega dog bones to make them fit ;)
Piston sizes are 2x40mm + 2x46mm
now originally i was looking at getting some R34 vspec 2/N1 rear brembos that measure 322mm, with 2 pot caliper, though these have been difficult to come by
so my second option is FG Typhoon brembos that are a 4 pot caliper with 330mm rotors, Brad from profab has dog bones that will make them fit so thats no issue
whats peoples opinions, are the typhoon brakes too big, has anyone given this a go? will they stuff up the bias of the brakes
i want to use the car for the odd track day but it will be mostly street.. and i wanna keep it all brembo btw
cheers
Personally I wouldn't bother upgrading the rears, but if you are dead keen the 33/34 brembo rears have been working fine on my race car for years. Just use more or less aggressive pads if they lock up before the fronts
To really bother upgrading the rear you need to have either removed a lot of weight from the front, or shifted a lot of weight rearwards. Standard weight distribution is about 2/3 front and 1/3 rear when static, and it is even more due to weight shift when you hit the brakes. As a result the rears do 9/10ths of stuff all.
Yes cosmetically I only wanted brembos for the rear, but if its deemed un necessary then I will leave as is
Duncan I do see your point, I haven't moved anymore weight around so I think you are right in the fact I probably don't really need to upgrade them. I thought there may have been some distinct advantage in having a bigger rear set up but if you guys reckon there's not then I might just leave them and put some upgraded pads on them
Cheers for the replys
Dont get too worried about back brakes. As long as your bias is good they will be ok. See photo for comparison. Note that with DS2500 pads my rear rotors are wearing out simply because the pads are hard on the rotors when they are cold.
I've got a big alcon kit for sale Joey haven't started a for sale thread but there is pics in my cars for sale thread sold the car without the brake kit :)
Haha thanks mick, but I just bought my Evo fronts.. Besides I've spent and about to spend enough cash lately... And I know what those Alcons are worth :(
  • 1 month later...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
