Hi All,
I'm in the process of buying my 1st v35! Very exciting times, and it will be quite a step up from my R31.
The car is currently undergoing its RWC and one of the items needed is new brakes all round.
Any suggestions on what work well with the skyline? Any personal preferences? I'm only using the car as a daily so I dont need anything stupid or excessive or expensive.
Cheers
https://www.sau.com.au/forums/topic/420689-what-brake-pads-do-you-use/
Much better than standard Bendix pads (and only marginally more expensive) are QFM HPX pads - email GSL Motorsport and they will hook you for $79 per axle. http://www.gslrallysport.com/
I thought that they were far more exxy than that. Might order a set in a few weeks. :)
EBC red stuff pads are great too
Overkill for general street use. No point really unless you've got 250rwkw everyday on the street, or you're tracking the car.
Don't get me wrong, I've got them on the front now and IMO, not worth it for daily driving.
I've got EBC redstuff front & rear, and I'm very happy with them. I will be doing numerous events in the car, hence the pad choice. That said, I've never braked hard on the street and though "shit - the brakes are too good, I should have bought cheaper pads" - so I don't agree with the "overkill for street use" comments.
Overkill for street use is because if the pads are designed for hard use, the pad will be harsh and increase rotor wear on a daily car, as the pad doesn't get up to temp.
QFM HPX is the go. Order fronts and rears and get free shipping from gsl rally sport.
Eggs-zachary!
On the street, you want decent stopping power and a pad that doesn't dust up a lot. That's it really. If you're driving hard on the street, take it to a track.
Yep, as pointed out, you don't want pads that take ages to heat up before they are effective, you don't really want HEAPS of brake dust on a street car, and most inportantly of all (as mentioned) most race-suited pads will rip the shit out of your rotors - who want to change rotors every 6 months?
Go with the HPXs - you won't be sorry! I have run them on my S15, R34 and V35 and love them - especially for the price.
The only reason that I didn't go with these was because I could only find them for $150+ a pair. That's when I thought, I've used EBC red stuff before, might as well stick with that.
HPX for that price. Shall purchase when I need new pads!
how's the brake dust with the HPX's? i'm guessing they're a bit dusty during bed in period but what are they like after that? might consider them next time i need pads also. Even though the EBC pads do a great job.
Remsa pads; also available through GSLRallysport are excellent.
​Dustier than QFM HPX, but apparently GSL were phasing out the HPX in favour of the Remsa's as their "Go to" pad.
Sits squarely between the HPX & AR1M pads for heat range, but not hard on rotors or noisy.
Around $90 per end.
They advertise them as being dust free, but they are not. In fact it is impossible to be dust free if you are grinding away microscopic amounts of metal every time you brake. But I find them to be pretty good on brake dust - significantly less than the Ferodo DS 2500s I used to run. Definitely happy overall.
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
    • Jousting sticks! Tell 'im he's dreamin!
    • GTR owners are wankers - 2025
