With the right offset and absolutely NO lipping or rolling of the guards whatsoever, it is absolutely possible to fit 275/40/17" Nitto NT555R's under the guards of your R33 GTS25t.
These are on a 17x8" rim and no i don't know the offset yet.
Examine:
Adrian
https://www.sau.com.au/forums/topic/42069-urban-skyline-myth-disproven/
275 means 27.5cm wide, 40 means the height is 40% of 275 = 11.0cm high. 17 is the diameter of the rims they fit.
I think the trick for the 275s must be in getting the right wheel offset, I had to roll my guards to get 265 to fit without rubbing under load
yeah, well i have this faxed bit of paper - they want measurements:
rear:
hub's face to outer gaurd distance
hub's face to inner most contact point such as spring etc distance
front:
hub face to inner lip of gaurd
hub face to closest steering/suspension
then they ask about offset - the guy said somehting about a offset of 20? so i will have 5" inside of face and 3". He reckons the tyre would almost be flush with the side?
i know **** all about this shit...bah
maybe i should scna the fax :)
Γ—
Γ—
