With the right offset and absolutely NO lipping or rolling of the guards whatsoever, it is absolutely possible to fit 275/40/17" Nitto NT555R's under the guards of your R33 GTS25t.
These are on a 17x8" rim and no i don't know the offset yet.
Examine:
Adrian
https://www.sau.com.au/forums/topic/42069-urban-skyline-myth-disproven/
275 means 27.5cm wide, 40 means the height is 40% of 275 = 11.0cm high. 17 is the diameter of the rims they fit.
I think the trick for the 275s must be in getting the right wheel offset, I had to roll my guards to get 265 to fit without rubbing under load
yeah, well i have this faxed bit of paper - they want measurements:
rear:
hub's face to outer gaurd distance
hub's face to inner most contact point such as spring etc distance
front:
hub face to inner lip of gaurd
hub face to closest steering/suspension
then they ask about offset - the guy said somehting about a offset of 20? so i will have 5" inside of face and 3". He reckons the tyre would almost be flush with the side?
i know **** all about this shit...bah
maybe i should scna the fax :)
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
    • It’s an rb25 so a gtst and I’ll get that valve
    • Thank you for this my turbo doesn’t have the nipple so I’ll get one installed in the turbo to Intercooler piping. I’ll get everything I need and locate it all using the information you both gave and get back with an update.
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
