The Facts;
1997 Nissan Skyline S2 GTS-t 40th Anniversary Model
Manual
150,xxx kms
ACT Rego until August 2013.
Car located in Phillip, ACT.
Price: $10k
Number: 0405 332 987 Call after 6pm or text during the day please
This car is in excellent condition for its year. Goes and sounds great! I purchased the car last november in NSW and I'm only selling it as I fancy a change - I don't usually even keep a car this long.
It has been professionally lowered (by previous owner - passed inspection in ACT no problem). It has 18" mags as shown in the pics with 225 tyres in the front and 265 on the rear - which were brand new when I bought it last year. It also has an after market dumpvalve but, apart from that and some Nismo(fake) seatcovers, this car is completly standard.
The interior is immaculate, and kept that way with the seatcovers and regularly cleaned. The body of the car has some very minor blemishes - all of which happened before I bought the car. A carpark rash on the rear driver wing and some minor marks above the exhausts are the most noteworthy, but again, very minor. I can have these fixed no problem if a deposit is given on the car. I had great plans to have them fixed but just didn't get around to it - yet.
The car flew through the roadworthy, only had to change some bulbs and wiper washer bottle! Goes to show how clean and reliable this car is.
I'm in absolutely no rush to sell the car so no low-ballers need apply! Also, as i don't fancy some young gun flinging the back end in to a wall, so I'll be doing the piloting on any test drive.
Price is slightly negotiable for a genuine buyer.
Just fancy a change so I'm also open to part/ex for something nice - no Holdens or Fords though - Euro or Jap only.
If you want to know anything else about the car just shoot me a text or email and I'll get back to you.
Thanks for looking!
  • 1 month later...
  • 4 weeks later...
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
