Lol long as I get a good tune and the power I want I don't care what it smells like lol
What power level are you going for and what is your current ? I doubled my power and got used/bored to it in 20minutes! All i got left is the smell :S
But 40litres is enough, unigroup guys told me to bring 60l just in case, but after a flush + tune i had 1/2+ a tank full left and 20litre bottle left.
https://www.sau.com.au/forums/topic/420718-e85/#findComment-6767620
What power level?
https://www.sau.com.au/forums/topic/420718-e85/#findComment-6767831
just going with 300kw
stock internals so dont wanna go over the top -
got the bolt ons to do the power - might as well do the fuel - its alot cheaper then $1.68 plus i am building a 30/25 on the side which i will run e85 on -
and from what i have seen if tuned properly this fuel is much better for the engine ect -
another main reason is i am currently running a tune on 7 psi as when i had my full tune the waste gate was failing so fixed a few things up and hopefulty this tune is good
its been alot of woork i had my car stripped and alot of stuff stolen a few years ago so been a slow process getting the car back to road worthy -
https://www.sau.com.au/forums/topic/420718-e85/#findComment-6768322
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
