http://www.arma3.com/alpha/briefing
To get in you have to buy one of the packs.
Beta access and the full game are also included in all the packs.
-ALPHA € 24,99
-DIGITAL DELUXE EDITION € 39,99
-SUPPORTER EDITION € 69,99
Pack info.
http://www.arma3.com/buy#buy
The Arma 3 Alpha runs from 5 March 2013 until the Beta becomes available (expected in Q2 2013).
https://www.sau.com.au/forums/topic/420734-arma-3/
steam powered is good.
paying for alpha testing? geez.
Looks like theyre adding new gear, tweaking the engine, adding a shit ton of set pieces and will somehow make the campiagn squeeze it all in.
Let's hope its not too "battlefield", but at the same time, its gonna have to be a hell of an improvement to make me want to buy it. I have a feeling the unpredictable AI and a strict campaign may hamper it.
https://www.sau.com.au/forums/topic/420734-arma-3/#findComment-6768303
its not really pay for alpha it is buy the game and get access to the alpha and beta and full game which i know i will do as arma is a favourite game of mine and would be great to start modding my missions into it
and with how the alpha is laid out it is basically how it should be with the community testing it and scripting on it to find issues before release as with arma it is made to be a modders game and make it how you like even though they added a single player campaign 99% of people i know that have arma never play the standard game or missions and play with all custom content
https://www.sau.com.au/forums/topic/420734-arma-3/#findComment-6768364
It's looking very good already, so many little things about arma2 that bugged me have been fixed up or changed. Graphics are nice as well.
Think I'll be buying the DDE version, cant really justify the extra cost for the Supporter version.
https://www.sau.com.au/forums/topic/420734-arma-3/#findComment-6772819
It has become a modders game. I was playing it online not long after release, and the only people playing it were military nuts, tactical shooter fans and military personnel. Most of the Aus and NZ servers were run by the Australian Army.
Lets be honest, the modding community for the engine was pretty small until DayZ. It almost single-handedly secured a solid budget for the sequel. I still reckon the only thing that makes the Arma series profitable (prior to DayZ sales and expansion packs) is the European market!
https://www.sau.com.au/forums/topic/420734-arma-3/#findComment-6772918
That's far from the truth yes dayZ did great things for arma2 but it has been a modders game since ofp and a perfect example of this is the projects such as ace, PR, i44 and all you have to do is look at the armaholic files db as I can guarantee that 95% of the mods were before dayZ and dayZ now is about 1 year old and also note that IronFront which is a mod for arma2 has become a standalone game like dayZ is and even has an expansion out now
Also Arma3 was in development a longtime before dayZ was created and was first released and dean hall was on the arma 3 dev team
You are half right about the servers as when it came out you had to be a millionaire to afford a server that could run the game let alone the bandwidth
But there has always been servers up and some of the main ones are the AEF and aus arma servers but with how arma works most us servers you can play on without an issue or how us in Deathinc play our custom missions is to host a server ourselves and play on it
https://www.sau.com.au/forums/topic/420734-arma-3/#findComment-6772956
  • 3 weeks later...
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
