So I'm having fuel pump problems ( no enough fuel ) and I'm thinking its not enough power to the pump so i've been doing some testing, these are my results..
voltage direct from alternator obviously while running (all testing idling at 2000rpm ) 13.5v
voltage at battery ( GTR, so in boot ) 13.2v
voltage at pump ( external, hard wired ) 12.8-13.1v
I need more power to the pump.... shouldn't I be seeing around 13.5v at the pump and 14v+ at the alternator???
I would really like 14v+ at the pump?
or is all that ok?
https://www.sau.com.au/forums/topic/420745-do-i-have-a-lazy-alternator/
You should be up around 14.5-14.8 volts
Not really.
13.8 Volts is the nominal voltage of a battery. 6 cells, 2.2V per Cell = 13.8V
With the engine running @ 2,000RPM and a healthy alternator, at the alternators output, you should see around the 14.0 - 14.2V mark.
At the fuel pump, Anything less than 12.5V isn't ideal at all. You want to have it around the 13.8V mark if you can. Cable size plays a big part in this. If you have factory wiring to the pump, change it out for something with a substantial cross sectional area to support the current and minimize voltage drop.
You dont want a car's electrical system too much above 14V, a lot of the electrics won't like it.
so lazy alternator ? yeah
pumps are direct wired to battery terminal with good thick cable, and best I've seem is 13.1v. @ 2k rpm
also just data logged on motec the voltage and no matter the revs it never got higher than 14.1v, during a 40 minute drive .
as I'm only seeing 13.5v at the alternator @ 2000rpm,....time to replace??
0.5v-1v could make all the difference in flow from pump..
no need to replace, seems fine.. sometimes it's actually the rectifier that's stuffed not the alternator... I believe on RBs, the rectifier is actually built into the alternator
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
