steve200b Posted September 22, 2014 Author Share Posted September 22, 2014 Thanks skyginer. Looking to paint the car now it's off the road for a bit as the converter ate itself on the weekend so I think I will do a rack and pinion steering conversion e85 and paint job over the next few months. Link to comment https://www.sau.com.au/forums/topic/420762-mr30-sleeper/page/4/#findComment-7394900 Share on other sites More sharing options...
steve200b Posted January 17, 2015 Author Share Posted January 17, 2015 Gearbox fixed again. New ecu lt16c with flex fuel and dash installed drives and runs smoother than the lt12 that was in it before. Just waiting for a drum of e85 to arrive to finish if the flex tune. Looks like I might be looking for a bigger turbo now the gearbox is sorted. Lol Link to comment https://www.sau.com.au/forums/topic/420762-mr30-sleeper/page/4/#findComment-7463087 Share on other sites More sharing options...
Nismo 3.2ish Posted January 17, 2015 Share Posted January 17, 2015 I hope it all works for you, Gearboxes must be getting hard on the pocket and with the extra power comes extra stress on everything. But it is all part of modifying these things , trying to get it all to work together and hope you have not over done it, haha Hard not to try and get what you want from your ride without going that little bit further to get it Link to comment https://www.sau.com.au/forums/topic/420762-mr30-sleeper/page/4/#findComment-7463088 Share on other sites More sharing options...
steve200b Posted January 26, 2015 Author Share Posted January 26, 2015 Lucky for me the guys at mv in Adelaide have covered most of the cost under warranty. No chance of being over it yet. If it was easy everyone would be doing it that's what I keep telling myself anyway. Lol Link to comment https://www.sau.com.au/forums/topic/420762-mr30-sleeper/page/4/#findComment-7467716 Share on other sites More sharing options...
mr30Turbo Posted March 13, 2015 Share Posted March 13, 2015 Put up a skid vid Link to comment https://www.sau.com.au/forums/topic/420762-mr30-sleeper/page/4/#findComment-7496310 Share on other sites More sharing options...
steve200b Posted April 2, 2015 Author Share Posted April 2, 2015 After the e85 tune I will put up a little vid. Lol Link to comment https://www.sau.com.au/forums/topic/420762-mr30-sleeper/page/4/#findComment-7508365 Share on other sites More sharing options...
steve200b Posted August 28, 2015 Author Share Posted August 28, 2015 It's that time. Lol Link to comment https://www.sau.com.au/forums/topic/420762-mr30-sleeper/page/4/#findComment-7595145 Share on other sites More sharing options...
steve200b Posted August 28, 2015 Author Share Posted August 28, 2015 New pipe work with no leaks helps Link to comment https://www.sau.com.au/forums/topic/420762-mr30-sleeper/page/4/#findComment-7595146 Share on other sites More sharing options...
steve200b Posted September 2, 2015 Author Share Posted September 2, 2015 Track plates ready for the weekend Link to comment https://www.sau.com.au/forums/topic/420762-mr30-sleeper/page/4/#findComment-7597334 Share on other sites More sharing options...
steve200b Posted June 7, 2016 Author Share Posted June 7, 2016 Been a while since any updates. Retune with 6boost and new cooler pipes was 350kw on 16psi. Car is apart finishing r31 rack conversion as no one can rebuild the steering box. Also modifying the rear control arm mounts to make them adjustable. Will add photos over the next month. 1 Link to comment https://www.sau.com.au/forums/topic/420762-mr30-sleeper/page/4/#findComment-7741970 Share on other sites More sharing options...
steve200b Posted June 20, 2016 Author Share Posted June 20, 2016 R31 conversion 1/2 done difference in hole location. Now time to mod the steering column Link to comment https://www.sau.com.au/forums/topic/420762-mr30-sleeper/page/4/#findComment-7748486 Share on other sites More sharing options...
steve200b Posted June 24, 2016 Author Share Posted June 24, 2016 Gtx35 ordered. Now I need to hurry the rack conversion so I can complete the turbo upgrade 1 Link to comment https://www.sau.com.au/forums/topic/420762-mr30-sleeper/page/4/#findComment-7750489 Share on other sites More sharing options...
AngryRB Posted June 24, 2016 Share Posted June 24, 2016 What size intercooler pipes? She's come together well since the early days, whats your power goal with the gtx35? Link to comment https://www.sau.com.au/forums/topic/420762-mr30-sleeper/page/4/#findComment-7750745 Share on other sites More sharing options...
steve200b Posted June 24, 2016 Author Share Posted June 24, 2016 21/2in hot side 3in cold pipe work. Let's see how much boost it takes to make 400kw. Lol 1 Link to comment https://www.sau.com.au/forums/topic/420762-mr30-sleeper/page/4/#findComment-7750763 Share on other sites More sharing options...
steve200b Posted June 30, 2016 Author Share Posted June 30, 2016 Gtx3582 should liven it up abit 1 Link to comment https://www.sau.com.au/forums/topic/420762-mr30-sleeper/page/4/#findComment-7752958 Share on other sites More sharing options...
steve200b Posted July 1, 2016 Author Share Posted July 1, 2016 New offset engine mounts as the r31 k frame requires the motor to move forward by 30mm and I don't want to modify the tail shaft. Motor moved forward 10mm and lifter it by 5mm to give better clearance. Link to comment https://www.sau.com.au/forums/topic/420762-mr30-sleeper/page/4/#findComment-7753347 Share on other sites More sharing options...
steve200b Posted July 1, 2016 Author Share Posted July 1, 2016 New offset engine mounts as the r31 k frame requires the motor to move forward by 30mm and I don't want to modify the tail shaft. Motor moved forward 10mm and lifter it by 5mm to give better clearance. Link to comment https://www.sau.com.au/forums/topic/420762-mr30-sleeper/page/4/#findComment-7753364 Share on other sites More sharing options...
steve200b Posted July 4, 2016 Author Share Posted July 4, 2016 Colum done. Just need to shorten the intermediate shaft then onto the turbo upgrade Link to comment https://www.sau.com.au/forums/topic/420762-mr30-sleeper/page/4/#findComment-7754062 Share on other sites More sharing options...
steve200b Posted July 6, 2016 Author Share Posted July 6, 2016 Made better use of the space the steering box removal left behind. Link to comment https://www.sau.com.au/forums/topic/420762-mr30-sleeper/page/4/#findComment-7754839 Share on other sites More sharing options...
steve200b Posted August 21, 2016 Author Share Posted August 21, 2016 Exhaust done for now. 2 Link to comment https://www.sau.com.au/forums/topic/420762-mr30-sleeper/page/4/#findComment-7768528 Share on other sites More sharing options...
