R32 RB26 head
Guys this head has only been on a car for 2 tunes and about 10 laps at winton. I kept having issues with the RB30 bottom end.
It was just rebuild and is sitting at the engine machinists now.
Specs
1mm Oversized valves on IN and EX
tommie cam cap bolts
Brass valve guides
HKS stage 2 cams 272/10.2
Welded on Rear oil return
Tomie valve springs
Ported
Decked
Hot tanked
Adjustable cam gears
ARP exhaust studs
Head and bottom end made 330rwkw on 12psi last tune with very little timing.
Not sure on price as this thing has costs $1,000's to build. So im open to offers on it
RB34 Stroker crank
Bought from spool imports, regrettable sale as i just need the cash atm. BRAND NEW still in box
$2000
PAR RB30 Conrods
Used for about the same time as the head was. In great condition
$500
Garret GT3540 turbo
Has rear housing coated in Jet Hot coatings 2000 series ceramic heat coating to ensure lower under bonnet temps
In good nic have kept oiled while out of the car. Needs external waste gate.
$1200
Greddy Coilovers
Type-S R32 Gts-t coilovers with std springs and a spare set of 10KG front springs.
in good condition used for about 20 laps at winton. No signs of leaking and no damage at all
Comes with the electronic damper control system
$1100
Nismo Twin plate
Clutch assembly and 2 brand new plates for it. I have not had time to put the 2 together But the clutch will be near new once done.
New plates cost $500 to get from japan
$1000
Lenso D1-R rims
18inch rim, 10 inch wide, -1 offset PAIR in silver, Rubber on them is no good.
$400
I am open to all reasonable offers on these items.
They are all located in woodend victoria. However i can bring them to hawthorn on a weekend for pickup.
Valves for the head are the following petpro valves
Intake 35.0 x 6.0 x 102.3mm #PP10265
Exhaust 30.6 x 6.0 x 101.7mm #PP10266
Not sure if they are oversized i was told they where at the time
I'm pretty sure forum rules say you have to list a price for the rb26 head and not put taking offers.
Cheers josh
so the clutch plates are the copper mix or which one??
sprung centre??
how much to ship to syd, and is clutch cover and fly wheel second hand??
Clutch is the older gmax style. Has brand new sprung centered plates from japan. The cover and fly are second hand but in great condition. They where all going in a project car with the RB34 crank but i need cash for other things right now :-( trust me its a regretful sale
Cheers josh
Josh as i said i am not sure what it is worth as i have spent 1000's
Based on the cost just to buy all the new parts in it i would say $4000 But im open to offers
Price on the head after going over all my receipts for machining and parts is $3000 thats what it would take for me to sell it
Hey PALADN. would it be possible to send me some up close shots of the inlet and exhaust ports and chambers please to 0400215126.
Cheers josh
Oh and also who done all the porting+polishing? And are the valves actually oversized? Or were you just told they were and ended up being standard sized after market ones.?
Cheers for your time again Josh.
Hey mate porting/polishing was done by reflex engineering in campbellfield.
Not sure on the valve those valves are the only ones petpro make and i couldnt find good intel on the std sizes.
  • 3 weeks later...
  • 3 months later...
R32 RB26 head
Specs
Brass valve guides
Tomie valve springs
Ported
Decked
Hot tanked
ARP exhaust studs
RB34 Stroker crank
$2000
PAR RB30 Conrods
$500
Garret GT3540 turbo
$1200
Greddy Coilovers
$1100
Nismo Twin plate
$1000
Lenso D1-R rims
$400
Hi,
What issues did you experience with the bottom end assembly?
KR
Sime
Edited by Stock e-Tune
    • I don't know....but I can't see how they would be. Different shape chassis and bumper means it is unlikely the reo is interchangeable. Doesn't mean it would be impossible to modify it to fit of course
    • They're supposed to not be compatible.
    • Evening fam, Pretty much what the title asks, I have looked all over and can’t find a proper answer expect one post from almost a decade ago which is vague. ive seen photos and they look pretty much identical, would an r33 GTR N1 reo work on an r32? reason I ask is they are cheaper to buy… $700 compared to 1k+ for an r32 n1 reo
    • Couldn't help myself, had to start putting it together.... It really is a solid bit of kit.  Probably stronger than i would have made it myself to be fair! 🤣🤣 Sweating like a pig after that.  Bloody hot and muggy day today, time for a swim now!
    • Yeah was thinking that. I've had the car go lower idle possibly around 650rpm every once in a long time after pouring fuel and would sound quite rough like a misfire, almost like it's shit fuel or something but who knows.
