R32 RB26 head
Guys this head has only been on a car for 2 tunes and about 10 laps at winton. I kept having issues with the RB30 bottom end.
It was just rebuild and is sitting at the engine machinists now.
Specs
1mm Oversized valves on IN and EX
tommie cam cap bolts
Brass valve guides
HKS stage 2 cams 272/10.2
Welded on Rear oil return
Tomie valve springs
Ported
Decked
Hot tanked
Adjustable cam gears
ARP exhaust studs
Head and bottom end made 330rwkw on 12psi last tune with very little timing.
Not sure on price as this thing has costs $1,000's to build. So im open to offers on it
RB34 Stroker crank
Bought from spool imports, regrettable sale as i just need the cash atm. BRAND NEW still in box
$2000
PAR RB30 Conrods
Used for about the same time as the head was. In great condition
$500
Garret GT3540 turbo
Has rear housing coated in Jet Hot coatings 2000 series ceramic heat coating to ensure lower under bonnet temps
In good nic have kept oiled while out of the car. Needs external waste gate.
$1200
Greddy Coilovers
Type-S R32 Gts-t coilovers with std springs and a spare set of 10KG front springs.
in good condition used for about 20 laps at winton. No signs of leaking and no damage at all
Comes with the electronic damper control system
$1100
Nismo Twin plate
Clutch assembly and 2 brand new plates for it. I have not had time to put the 2 together But the clutch will be near new once done.
New plates cost $500 to get from japan
$1000
Lenso D1-R rims
18inch rim, 10 inch wide, -1 offset PAIR in silver, Rubber on them is no good.
$400
I am open to all reasonable offers on these items.
They are all located in woodend victoria. However i can bring them to hawthorn on a weekend for pickup.
Valves for the head are the following petpro valves
Intake 35.0 x 6.0 x 102.3mm #PP10265
Exhaust 30.6 x 6.0 x 101.7mm #PP10266
Not sure if they are oversized i was told they where at the time
I'm pretty sure forum rules say you have to list a price for the rb26 head and not put taking offers.
Cheers josh
so the clutch plates are the copper mix or which one??
sprung centre??
how much to ship to syd, and is clutch cover and fly wheel second hand??
Clutch is the older gmax style. Has brand new sprung centered plates from japan. The cover and fly are second hand but in great condition. They where all going in a project car with the RB34 crank but i need cash for other things right now :-( trust me its a regretful sale
Cheers josh
Josh as i said i am not sure what it is worth as i have spent 1000's
Based on the cost just to buy all the new parts in it i would say $4000 But im open to offers
Price on the head after going over all my receipts for machining and parts is $3000 thats what it would take for me to sell it
Hey PALADN. would it be possible to send me some up close shots of the inlet and exhaust ports and chambers please to 0400215126.
Cheers josh
Oh and also who done all the porting+polishing? And are the valves actually oversized? Or were you just told they were and ended up being standard sized after market ones.?
Cheers for your time again Josh.
Hey mate porting/polishing was done by reflex engineering in campbellfield.
Not sure on the valve those valves are the only ones petpro make and i couldnt find good intel on the std sizes.
  • 3 weeks later...
  • 3 months later...
R32 RB26 head
Specs
Brass valve guides
Tomie valve springs
Ported
Decked
Hot tanked
ARP exhaust studs
RB34 Stroker crank
$2000
PAR RB30 Conrods
$500
Garret GT3540 turbo
$1200
Greddy Coilovers
$1100
Nismo Twin plate
$1000
Lenso D1-R rims
$400
Hi,
What issues did you experience with the bottom end assembly?
KR
Sime
Edited by Stock e-Tune
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
