Hello there I have a major problem with my skyline I changed my spark plugs and now the car sounds like an wrx .. When you turn over the car it starts to shake the Motor just was requiring is this is a comment problem I am thinking of changing my coil packs but wondering if that's going to work and this is my first time owning a skyline so I need some help thanks people for your time in reading this
https://www.sau.com.au/forums/topic/420771-need-some-assistance-for-my-skyline/
One of your cylinders isn't firing. Start the car up and begin removing coilpack loom plugs, one at a time, to see if it makes a difference to the sound of the engine (i.e. running on 4 cylinders instead of 5). When you pull one off and it doesn't make a difference (i.e. still running on 5), that is the problem cylinder. Once you've sussed it out...just remove that coilpack and spark plug...then re-install...should fix whatever issue you have. Sounds like something wasn't connected back properly because it was working prior to the spark plug change.
Sounds similar to the issue I had last week and it turned out to be a dead Coil Pack.
Let the car idle and unplug one injector at a time. When you find an injector that you can unplug without changing the car's idle then you have found the cylinder with the issue. If for example, cylinder 3 isn't firing - swap coil pack 2 and 3 around. Run the same test as above. If the issue is now occurring with cylinder 2, you know it's the coil pack. If not, could be the injector.
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
