Hello there I have a major problem with my skyline I changed my spark plugs and now the car sounds like an wrx .. When you turn over the car it starts to shake the Motor just was requiring is this is a comment problem I am thinking of changing my coil packs but wondering if that's going to work and this is my first time owning a skyline so I need some help thanks people for your time in reading this
https://www.sau.com.au/forums/topic/420771-need-some-assistance-for-my-skyline/
One of your cylinders isn't firing. Start the car up and begin removing coilpack loom plugs, one at a time, to see if it makes a difference to the sound of the engine (i.e. running on 4 cylinders instead of 5). When you pull one off and it doesn't make a difference (i.e. still running on 5), that is the problem cylinder. Once you've sussed it out...just remove that coilpack and spark plug...then re-install...should fix whatever issue you have. Sounds like something wasn't connected back properly because it was working prior to the spark plug change.
Sounds similar to the issue I had last week and it turned out to be a dead Coil Pack.
Let the car idle and unplug one injector at a time. When you find an injector that you can unplug without changing the car's idle then you have found the cylinder with the issue. If for example, cylinder 3 isn't firing - swap coil pack 2 and 3 around. Run the same test as above. If the issue is now occurring with cylinder 2, you know it's the coil pack. If not, could be the injector.
    • Welcome!  How long have you had it? And what colour is it?
    • "CAD" version 1.0 It will have a 15mm lip around the top for 6 × 5 or 6mm nutserts and fixtures (two on each of the three straight edges), and some pinch weld on any exposed edges, it has three mounting points, one of the power steering reservoir bolts, and two on the rad support, my 120mm hole saw will make short work of hole for the silicone joiner, with ample room for some pinch weld  I've also got enough Carbuilders "peel and stick" heat shield to cover the outside of it at the coolant expansion tank and on the engine side, as pictured, and internally on the lid and where the fuse box is, I've also got some thin, about 3mm, black 3M single sided sticky foam stuff that was left over after sealing some door drafts at home to help seal the lid As for the shape, it "sort of" matches the shape of the fuse box, so shouldn't look to "out of place" The lower area and hole for the intake will need pinch weld with a balloon on it to fully seal the hole and bottom of it, that will happen after it has been fabricated so I know exactly what size is required  Filter service has been trialed,  and so far it was a simple process  Just need to get some alloy, and then head into work to use the guillotine and break press in the workshop Hopefully it should be sorted in a week or two Guestimated outlay will be under a $50 for the stuff I don't have on hand (alloy, 6mm nutserts, the pinch weld, and wrinkle paint) Disclaimer: That's what the "voices in my head" are telling me how the filter box should end up getting done......lets see if they know what they are talking about
    • Have been polishing up the trailer rims as they had been sitting in the shed for a few years and are really in need of some love. This was after a couple of passes with chrome polish - coming up quite well ✅ .
    • Welcome aboard! Is your Skyline auto or manual? I'm assuming manual. Does it have any mods done yet?
    • Hey mate, the brown and grey plugs would usually go to the TPS, brown one goes on the bottom connector and grey is the top but isn't used unless the car is auto, your TPS looks different to mine though I've got a series 2 engine.
