Ssr Professor Sp1 (F 18X9 +19, R 18X9.5 +18) 5X114.3, S14/s15 Gab Prosso Zero (2 Way Adj With Adj Camber Tops)
SSR Professor SP1
F 18X9 +19 (215/45s Bridgestone Potenza tires ~90% tread)
R 18X9.5 +18 (235/40s Continental contisport contact 3 tires ~90% tread) ~11cm Dish
Condition of rims is ok but have some gutter rash from previous owner.
Comes with spare original ssr valve stems and caps
PICK UP ONLY
$2500 ONO
GAB prosso zero 2 way adjustable coilovers with camber top adjustment.
A bit dusty and dirty in photo but in great condition.
PICK UP ONLY
$1100 ONO
Located in the Northern Suburbs Melbourne
Edited by mike_s15
    • I do have their “Nissanie Motorsports Co.” vin plates, but I am curious if anyone would have more info on them. Like how many cars they’ve imported and whatnot
    • Been a long while since i have updated this money pit lol.  Have had a few tune related issues with the car, first blowing the frost plug out the back of the head and then blowing the headgasket 3 months later, which has now been retuned and sorted. Done a few little changes along the way as well, i wasn't happy with the wheel and brake setup, so start of last year i managed to get myself a set of r35 brakes and nismo lmgt4 18x10.5 +15 Upgraded to now running a Precision Gen 2 6870 with a 1.15ar, to be honest felt more like a downgrade as the car feels much lazier around town compared to the Gen2 6466 previously. 0761719E-5683-43F7-BD3B-4BD94335DFF4.mov
    • Hi there, i am currently using the Elmers Racing Billet merge collector, we are using sch40 tubing and 1.5" ID, no cracks so far. however if i was to do it again, i would go sch10 with 1.25" runners
    • I haven't touched the turbos so might need to look at that 👍 Appreciated 🙏
    • If you haven't replaced the OEM turbos, replace them sooner than later. I have seen recent pictures of what OEM ceramic turbo failure can do in an RB26 and it will make a 10k AUD budget look like a joke. Single vs twins have been done to death on this forum. If your turbos haven't fallen apart you can probably send yours off to Hypergear for rebuild. The journal bearing option will have more turbo lag but it's a good bit cheaper. I would probably go for ball bearing CHRA but keep in mind ball bearing turbos are more particular about oil pressure/flow.
