ok yesterday pulled the pipe off that goes between my intake and Stock BOV and i put my hand on the outlet and it feels like air is leaking out.
can i block this valve up cause it feels like its leaking on just idle.
https://www.sau.com.au/forums/topic/420805-stock-recirc-valve-leaking/
are they supposed to cause i was under the impression that the BOV shouldnt leak at all only when released when off throttle.
If this is so would blocking the recirc valve like a plate to block it all do any justice or damage to my motor or alter AFR?
Not sure why they leak but as long as the air is recirculating within the piping it is ok.
If it's not plumbed back in, then there is an air leak which causes issues.
Leave it as it should be.
You can tap and grub screw the bleed hole, it works ok, but drivability will suffer. It can shudder a bit when backing off from boost to a light cruise.
The factory put the hole there for a reason, to make it drive smoothly. If you are still on the stock ecu, it's best to leave it alone.
ok kool so what if i replaced it with a exit atmo BOV it will play up im guessing also with a 10 psi limit can i put another spring inside the unit or somthin so i can leave it stock and run more boost?
Don't do that, you're going back to the dark ages.. just leave it how it is. I ran 1.3bar though a stock BOV no dramas at all, a simple relatively mod is to crush the top hat down using a vice to put more tension on it.
But you're running 0.7bar of boost, don't waste your time with it.
Its designed this way to stop reversion and to smooth the idle, nearly all skylines are supposed to do it.
ok so what about block the BOV up all together i really hate the noise to be honest ive lost my licence before and i now require my licence for work so last thing i want is attention from coppers with noise my car is stock thought has 3 inch exhaust and yer im abit worried about that aswell.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
