yer cause all i have is a pod filter and exhaust atm.
wanted to get rid of the bov and im about to fit the rest of my 3 inch exhaust system but now i require my licence for work im having 2nd thoughts
No, because you are pressurising the entire engine. I just remove the afm, plug the pipe and fill with compressed air to around 20-30psi. The closed exhaust valves usually hold the air back from my experience.
I tried this, only my plug was just after the turbo outlet. Air would leak out from the rocker covers or something, would hold bugger all pressure.
If there was a plug at the throttle body aswell as plugging all the hoses to the recirc valve and plenum, etc. Would the BOV still be closed shut and not leak, or because theres no pressure from the plenum being applied to the back of the recirc valve, it would be open slightly (like on idle?) and lose pressure?
Im sure theres a smarter way to explain what i mean but thats all i got lol.
ok so what about block the BOV up all together i really hate the noise to be honest ive lost my licence before and i now require my licence for work so last thing i want is attention from coppers with noise my car is stock thought has 3 inch exhaust and yer im abit worried about that aswell.
A stock BOV will make almost no noise ASSUMING you have the stock airbox fitted. It sounds like your real issue is a pod filter, etc.
However I will say that it can easily be heard operating with metal intake and pod, even during partial throttle and lifting slowly off the throttle.
I've noticed this with both my original stock rb25 and my current stock rb26 bov. I can hear it opening slightly at very light throttle loads audibly.
However I will say that it can easily be heard operating with metal intake and pod, even during partial throttle and lifting slowly off the throttle.I've noticed this with both my original stock rb25 and my current stock rb26 bov. I can hear it opening slightly at very light throttle loads audibly.
+1 to all he said.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
