au55ie Posted February 28, 2013 Share Posted February 28, 2013 Hey guys, I'm half way through fitting a front mount and am wondering g what to do with the washer bottle set up in the front right corner. The piping will foul it. Do I mount it else where or ditch it? Link to comment https://www.sau.com.au/forums/topic/420816-r34gtt-fmic-fitting-question-wat-to-do-with-washer-bottle/ Share on other sites More sharing options...
au55ie Posted February 28, 2013 Author Share Posted February 28, 2013 found my answer. i just got a universal washer bottle from bursons. problem solved Link to comment https://www.sau.com.au/forums/topic/420816-r34gtt-fmic-fitting-question-wat-to-do-with-washer-bottle/#findComment-6769075 Share on other sites More sharing options...
TTT Posted March 1, 2013 Share Posted March 1, 2013 Thats one of the reasons people tend to buy return flow coolers so it uses the stock pipes in the engine bay. Link to comment https://www.sau.com.au/forums/topic/420816-r34gtt-fmic-fitting-question-wat-to-do-with-washer-bottle/#findComment-6769283 Share on other sites More sharing options...
34GeeTeeTee Posted March 1, 2013 Share Posted March 1, 2013 Thats one of the reasons people tend to buy return flow coolers so it uses the stock pipes in the engine bay. I did it becuase i went high mount and FFP.... Ill have to locate the washer bottle on the passenger side as the oil cooler has taken up the rest of the space where the washer bottle was.... Link to comment https://www.sau.com.au/forums/topic/420816-r34gtt-fmic-fitting-question-wat-to-do-with-washer-bottle/#findComment-6769289 Share on other sites More sharing options...
au55ie Posted March 1, 2013 Author Share Posted March 1, 2013 i know a return flow would have been easier- but when you buy chinese crap to save money it bites u in the arse. Link to comment https://www.sau.com.au/forums/topic/420816-r34gtt-fmic-fitting-question-wat-to-do-with-washer-bottle/#findComment-6769492 Share on other sites More sharing options...
Hanaldo Posted March 1, 2013 Share Posted March 1, 2013 Return flows aren't all made in China... Link to comment https://www.sau.com.au/forums/topic/420816-r34gtt-fmic-fitting-question-wat-to-do-with-washer-bottle/#findComment-6769573 Share on other sites More sharing options...
au55ie Posted March 1, 2013 Author Share Posted March 1, 2013 next problem? where to run the boost line? if thats what it is? the stock pipe that feeds into the intake had a nipple but nothing on the new one. where do i fit it? do i put a barb into the silicone joiner from the cold side where it meets the stock intake pipe? i know this a noob question but i gota learn some how cheers Link to comment https://www.sau.com.au/forums/topic/420816-r34gtt-fmic-fitting-question-wat-to-do-with-washer-bottle/#findComment-6769773 Share on other sites More sharing options...
GTSBoy Posted March 1, 2013 Share Posted March 1, 2013 It's best if it is sourced from close to the compressor outlet. If you have to drill and weld a fitting, then that's what you should do. Link to comment https://www.sau.com.au/forums/topic/420816-r34gtt-fmic-fitting-question-wat-to-do-with-washer-bottle/#findComment-6769871 Share on other sites More sharing options...
au55ie Posted March 1, 2013 Author Share Posted March 1, 2013 i just got a screw in brass barbed fitting toi fit into the pipe work. do i fit it on the hot or cold side of the cooler??? Link to comment https://www.sau.com.au/forums/topic/420816-r34gtt-fmic-fitting-question-wat-to-do-with-washer-bottle/#findComment-6770102 Share on other sites More sharing options...
GTSBoy Posted March 1, 2013 Share Posted March 1, 2013 See my previous post? Link to comment https://www.sau.com.au/forums/topic/420816-r34gtt-fmic-fitting-question-wat-to-do-with-washer-bottle/#findComment-6770134 Share on other sites More sharing options...
au55ie Posted March 1, 2013 Author Share Posted March 1, 2013 yes i saw ur post. the original nipple was on the cold side near the intake pipe. thats why i asked. so would it be better to move it to the hot side near the compressor outlet or just put ib back where the original was? Link to comment https://www.sau.com.au/forums/topic/420816-r34gtt-fmic-fitting-question-wat-to-do-with-washer-bottle/#findComment-6770153 Share on other sites More sharing options...
GTSBoy Posted March 2, 2013 Share Posted March 2, 2013 That may have been where it was, but not where it was when it came out of the factory. Link to comment https://www.sau.com.au/forums/topic/420816-r34gtt-fmic-fitting-question-wat-to-do-with-washer-bottle/#findComment-6770220 Share on other sites More sharing options...
gotRICE? Posted March 3, 2013 Share Posted March 3, 2013 That may have been where it was, but not where it was when it came out of the factory. Ill think you'll find that its actually on the cold pipe from factory. Link to comment https://www.sau.com.au/forums/topic/420816-r34gtt-fmic-fitting-question-wat-to-do-with-washer-bottle/#findComment-6770933 Share on other sites More sharing options...
GTSBoy Posted March 3, 2013 Share Posted March 3, 2013 My R34 turbo has the fitting on compressor housing. I've also seen them on the turbo outlet elbow. There are no spare ports on my R34 crossover pipe for boost control sensing. All are used for the things they were supposed to be used for. Link to comment https://www.sau.com.au/forums/topic/420816-r34gtt-fmic-fitting-question-wat-to-do-with-washer-bottle/#findComment-6771029 Share on other sites More sharing options...
gotRICE? Posted March 3, 2013 Share Posted March 3, 2013 oops. as you were. was talking about 33. Haha. forgot this was a 34 thread. Link to comment https://www.sau.com.au/forums/topic/420816-r34gtt-fmic-fitting-question-wat-to-do-with-washer-bottle/#findComment-6771031 Share on other sites More sharing options...
89CAL Posted March 3, 2013 Share Posted March 3, 2013 Washer bottle ideas: This is where I put mine, bit of re-wiring, bit of water tube re-routing and all good. Bracket was pretty straight forward to make as well Link to comment https://www.sau.com.au/forums/topic/420816-r34gtt-fmic-fitting-question-wat-to-do-with-washer-bottle/#findComment-6771046 Share on other sites More sharing options...
au55ie Posted March 5, 2013 Author Share Posted March 5, 2013 got it finished... yew! next time i will spend the dollars on a proper r34 kit, there were endless issues with the piping. i replaced all the silicone joiners that were supplied as they were all to short or the wrong angle. car has never driven so nice, its amazing how much more response it has with the FMIC and 3" turbo back exhaust. cheers boys Link to comment https://www.sau.com.au/forums/topic/420816-r34gtt-fmic-fitting-question-wat-to-do-with-washer-bottle/#findComment-6773171 Share on other sites More sharing options...
MrFijiGold Posted March 6, 2013 Share Posted March 6, 2013 Why do all piping kits come in 3 piece only? Does anyone know of an RB25 kit that has the turbo to intercooler pipe included?89CAL that is a very nice setup you have. Good well done Link to comment https://www.sau.com.au/forums/topic/420816-r34gtt-fmic-fitting-question-wat-to-do-with-washer-bottle/#findComment-6774173 Share on other sites More sharing options...
89CAL Posted March 6, 2013 Share Posted March 6, 2013 Turbo to intercooler pipe? Thought most non return kits came with one of these or did you mean a return flow kit? Link to comment https://www.sau.com.au/forums/topic/420816-r34gtt-fmic-fitting-question-wat-to-do-with-washer-bottle/#findComment-6774537 Share on other sites More sharing options...
MrFijiGold Posted March 6, 2013 Share Posted March 6, 2013 The hot side pipe that comes of the turbo compressor and fits onto the 'cooler, I understand that there is only one hot side pipe that goes half way. So basically what I am after is a inter cooler piping kit that goes from throttle body to turbo. I am running a GT3037S Link to comment https://www.sau.com.au/forums/topic/420816-r34gtt-fmic-fitting-question-wat-to-do-with-washer-bottle/#findComment-6774910 Share on other sites More sharing options...
