Ok car was goin perfect but yesterday morning it suddenly had like no power when i accelerated, it would do the turbo wind up and all but just no power, later the car went weird wouldnt rev past 3.5 rpm, smoke coming out exhaust, hunting idle, misfiring. I replaced spark plugs, tested coils (splitfires), check aac valve, check for vacuum leaks checked maf, checked intercooler.. Things done before prob i adjusted boost and put 20 dollars prem fuel in car.... Please help im seriously stumped car has fc commander, splitfire coils, stock bov, pod filter etc. 1994 r33 manuel
Edited by Nige1
I'm having the same sort of problem, car won't idle, misfires, heaps of black smoke. I haven't even tried to drive it, won't hold revs. The day before i took the coil packs out and taped them up, to fix a miss at boost, which it did fix. gave it a bit of a hiding and the next day it wouldn't run. just put a brand new set of yellow jackets in there, changed plugged, can't find any cooler leaks or vaccuum leaks. cleaned the maf
just about ready to try get it towed to a mechanic
I know what you mean, mine drives rough when it hits 3.5 rpm it starts misfiring hard and revving out and the idles fine until i rev it then it goes to stall but regains it self idles shit for a few seconds thn kinda goes bak to alright but not fully
have you checked it....im assuming a Z32? from what your saying it seems like it could be playing up causing your car to over fuel (at a guess). Start there! try cleaning it. Try disconnecting it when the car is idling there will be tell tale signs. If you have a spare or know someone try replacing it...
Me and mate have narrowed it to either afm, bad petrol or the fc commander.... Does this sound possible??
my guess is AFM sending incorrect voltages to the ECU causing the car to over fuel/under fuel! i have had similar issues with a Z32 in the past (or AFM in general)
Edited by Frosty
you sure you havnt got a vacumn leak? Ive found with mine that raising the boost is blowing out the intake manifold gasket, when that happens its either too lean or too rich, runs rough
I put boost down to low after tht but prob still there
get a can of wd or crc and put the straw tip on, then try spraying round the intake manifold gaskets and bov while its running
if it starts reacting then its confirmed, and check the clamps are tight
Edited by AngryRBGTX
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
