Ok car was goin perfect but yesterday morning it suddenly had like no power when i accelerated, it would do the turbo wind up and all but just no power, later the car went weird wouldnt rev past 3.5 rpm, smoke coming out exhaust, hunting idle, misfiring. I replaced spark plugs, tested coils (splitfires), check aac valve, check for vacuum leaks checked maf, checked intercooler.. Things done before prob i adjusted boost and put 20 dollars prem fuel in car.... Please help im seriously stumped car has fc commander, splitfire coils, stock bov, pod filter etc. 1994 r33 manuel
Edited by Nige1
I'm having the same sort of problem, car won't idle, misfires, heaps of black smoke. I haven't even tried to drive it, won't hold revs. The day before i took the coil packs out and taped them up, to fix a miss at boost, which it did fix. gave it a bit of a hiding and the next day it wouldn't run. just put a brand new set of yellow jackets in there, changed plugged, can't find any cooler leaks or vaccuum leaks. cleaned the maf
just about ready to try get it towed to a mechanic
I know what you mean, mine drives rough when it hits 3.5 rpm it starts misfiring hard and revving out and the idles fine until i rev it then it goes to stall but regains it self idles shit for a few seconds thn kinda goes bak to alright but not fully
have you checked it....im assuming a Z32? from what your saying it seems like it could be playing up causing your car to over fuel (at a guess). Start there! try cleaning it. Try disconnecting it when the car is idling there will be tell tale signs. If you have a spare or know someone try replacing it...
Me and mate have narrowed it to either afm, bad petrol or the fc commander.... Does this sound possible??
my guess is AFM sending incorrect voltages to the ECU causing the car to over fuel/under fuel! i have had similar issues with a Z32 in the past (or AFM in general)
Edited by Frosty
you sure you havnt got a vacumn leak? Ive found with mine that raising the boost is blowing out the intake manifold gasket, when that happens its either too lean or too rich, runs rough
I put boost down to low after tht but prob still there
get a can of wd or crc and put the straw tip on, then try spraying round the intake manifold gaskets and bov while its running
if it starts reacting then its confirmed, and check the clamps are tight
Edited by AngryRBGTX
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
