Hi Guys
I ordered the following last week and would like some advice on what tyres to use and also will i need to roll up the fender .
Varrstoen 2.2.2 19 inch Wheels 9.5 / 10.5
Any one have a roll up fender like Eastwood Fender Roller tool, i dont think the baseball bat techniques will give great results
cheers
Fred
https://www.sau.com.au/forums/topic/420835-wheels-advise/
tyre choice has been covered heaps of times, give the search function in this section a go and have a read of what some people have said about tyres. You can stretch pretty much any tyre. You'll need to lower the car if you want it to look like the above picture
https://www.sau.com.au/forums/topic/420835-wheels-advise/#findComment-6770098
can i go for
Front – 19x9 +25
Rear – 19x10 +25
My wheels are 20x8.5 and 20x10 +25 front and back and they sit inside the guards a fair bit at the front. Back wheels need probably a 15mm spacer to be flush and I'd say a 25mm at the front to be flush or there abouts. Try to get close to low teens offsets and you'll be sitting pretty.
https://www.sau.com.au/forums/topic/420835-wheels-advise/#findComment-6783320
  • 2 months later...
strech,?
height?
will be pretty haggas looking without a decent drop
this is a 19x9-11 with a 215/35/19 (will prob go a 225 next time) thats the equivilent of 10.5+7
But you hmay have some iussues with inner clearance on lock with the extra width
whole car for reference,
19x9-11 215/35/19 and 19x10.5-3 245/35/19
Coils maxed out low
Rears guards rolled, fronts untouched
http://i260.photobucket.com/albums/ii32/Locky180/20130419_161909_zpsd135f818.jpg
Edited by (Locky)
https://www.sau.com.au/forums/topic/420835-wheels-advise/#findComment-6856680
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
