As people may or may not know the 2 in japanese is ni and 3 is san so i have the plate for sale 023.GTR this is white with black letters $1500ono
Also have 523.GTR also white with black type ( 5 in japanese is go) $1250 ono
These plates are only $99per year
https://www.sau.com.au/forums/topic/420841-number-plate-suit-any-gt-r/
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
