All items located in Adelaide . Pickup preferred however will post at your expense.
1. R34 gtr vspec intercooler - $200
2. R34 gtr fuel pumps x 2 - $100 each
3. R34 gtr ecu - $120
4. R34 gtr coil packs x 2 sets - $120 per set
5. R34 gtr power fc with hand controller - $700
6. R34 gtr gear knob - $100
7. R34 gtr nismo white face cluster (80000kms) - $400
Will get some pics up or can sms straight too you . We all know what this stuff looks like
Nick - 0402523895
https://www.sau.com.au/forums/topic/420856-34-gtr-parts/
Price drop for today only ! After today price goes back to normal . Welcome to place a deposit to hold if you can't afford the full amount .
Intercooler - was $200 now $150
Fuel pumps - was $100 now $70 each
Coil packs- was $120 now $85 per set
Power fc with controller - was $700 now $595
Gear knob - was $100 now $65
Nismo cluster - was $400 now $320
Cheers
Nick - 0402523895
https://www.sau.com.au/forums/topic/420856-34-gtr-parts/#findComment-6776828
Nismo cluster - $380 posted
Fuel pumps - $90 posted
Coils - $100 per set posted
Power fc - $600 posted
Cooler - $150 plus postage
All prices firm. Will simply not respond to any other offers .
Thanks
Nick
0402523895
https://www.sau.com.au/forums/topic/420856-34-gtr-parts/#findComment-6791036
  • 3 weeks later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
